Radius-ing heads, Any performance advantage? |
krazykonrad |
Sep 18 2017, 08:41 AM
Senior Member Group: Members Posts: 1,126 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Is there any performance advantage here or is it just to back off the compression ratio to avoid pinging? Thanks, Konrad |
Mark Henry |
Sep 18 2017, 12:27 PM
Also called the Semi-Hemi, I used to do this back in the early nineties.
OK if you want to lower your CR, but I've found doing the math and shims under the barrels do a simpler and performance wise better job. |
Lo-Fi Version | Time is now: 16th May 2024 - 03:14 AM |
