New Cell |
New Cell |
Cracker |
Sep 18 2017, 06:21 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Well this was a long overdue upgrade...there were a couple issues with the PMS cell that came with the car. The low capacity of the PMS cell (10 gallons) means I have a limited session length of about 25 minutes - max. It is also a PITA to remove the cell with the supply/return connections located on the bottom of the unit - like an original tank. It also became difficult to tie in a swirl pot...
The solution? The cell from Fuel Safe - I am impressed with the fit and finish with the only real disappointment being the lack of thought put into securing it in the car. It also has a Deatsch Werks in-tank pump with big capacity and power. All of the connections now exit through the cover plate on the topside of the cell. I elected to have the Holley Fuel map attached to the pick-up but this was probably not necessary on my application. Here it is... Tony |
cali914 |
Sep 21 2017, 12:15 AM
cali914 Group: Members Posts: 447 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
Does that fit on top of the front sway bar? It looks great and I bet you don't have any problems with the fuel sending unit. Ha Ha Ha
gms |
Sep 21 2017, 09:45 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Very nice, is that a stock tank they build or a custom you had them make?
Jetsetsurfshop |
Sep 21 2017, 11:09 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
How much fuel does that setup hold now?
Cracker |
Sep 21 2017, 07:34 PM
Cali - Yes, a modern, reliable sending unit is nice!
Glenn - This is not the PMS "stock" tank they make...it does fit nicely in the stock location but has much more capacity than the other unit. Shane - 14 gallons |
pcar916 |
Jan 8 2018, 06:23 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
wes |
Jan 8 2018, 07:07 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Looks great, guessing it’s a spendy addition.
Cracker |
Jan 8 2018, 07:16 PM
Thank you fellas...I have been able to use it twice on track - no drama and I was able ro bring the swirl pot back online. Yes, a little spendy...
Tony |
campbellcj |
Jan 12 2018, 10:03 AM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Looks good! I have had the PMS-FS cell in mine for many years and can confirm issues with both capacity and fuel sender/gauge function. As I've only run 20-30 min sessions to-date it has not been a 'problem' but it does overflow readily if overfilled and I've done that a number of times (IMG:style_emoticons/default/huh.gif) . I typically fill 4-5 gals per session and run it down to a 1-2 gal reserve, aiming to end the session with the low-fuel light (light works but not gauge, will troubleshoot that someday) just starting to flicker and no starvation in corners. Basically my fuel gauge is knowing the car's burn rate is ~ 1gal/5mins at speed...
Lo-Fi Version | Time is now: 1st May 2024 - 04:51 PM |
