New Cell |
New Cell |
Cracker |
Sep 18 2017, 06:21 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Well this was a long overdue upgrade...there were a couple issues with the PMS cell that came with the car. The low capacity of the PMS cell (10 gallons) means I have a limited session length of about 25 minutes - max. It is also a PITA to remove the cell with the supply/return connections located on the bottom of the unit - like an original tank. It also became difficult to tie in a swirl pot...
The solution? The cell from Fuel Safe - I am impressed with the fit and finish with the only real disappointment being the lack of thought put into securing it in the car. It also has a Deatsch Werks in-tank pump with big capacity and power. All of the connections now exit through the cover plate on the topside of the cell. I elected to have the Holley Fuel map attached to the pick-up but this was probably not necessary on my application. Here it is... Tony |
Cracker |
Sep 21 2017, 07:34 PM
Cali - Yes, a modern, reliable sending unit is nice!
Glenn - This is not the PMS "stock" tank they make...it does fit nicely in the stock location but has much more capacity than the other unit. Shane - 14 gallons |
pcar916 |
Jan 8 2018, 06:23 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:14 AM |
