| grantsfo |
May 20 2005, 06:49 PM
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
My car turns now!!!! Rich and the guys at HPH installed new 175lb Eibach springs and adjustable pearches for me today along fixing my brakes with new rotors and Porterfield r-4 pads. Took a few fast uphill corners where my car has typically pushed all the way around the turn and the front end just tucked in and held. Yee haw! I'll see if its too much this weekend at Marina, but I still have a lot of adjustment left in my front 22mm bar. Car didnt bounce around any more with the new 175 lb springs than with my 140 lb springs on my trip up the twisty mountain road to my house. I think I made a very good decision going with heavier rear springs. Thanks again to HPH for getting me set!
...So a car that turns and can stop is worth how many seconds in a AX? Nathan and Trekkor nice seeing you guys there today. |
| Mueller |
May 20 2005, 06:57 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
did you go with the perch kit from Coleman Racing or did you get everything from Rich??
i need to order a kit soon for my Konis that I plan on getting in the next few weeks.... |
| grantsfo |
May 20 2005, 06:58 PM
Went with the kits Rich sells. |
| Trekkor |
May 20 2005, 08:25 PM
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
yessssss!
The Eibach on Koni's with the Ground Control threaded collar seems to be the hot set-up. Now Grant will beat me, too. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) KT |
| grantsfo |
May 20 2005, 09:09 PM
Naw were pretty closely matched. My car is lighter, but you'll get me on the straights with about ...what twice as much HP? We need to gang up on Nathan. Maybe I can distract him when you let the air out of his tires! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 21st June 2026 - 08:59 PM |
