Considering Selling My Cherished Met Green 6 |
stevesc_us |
Sep 22 2017, 06:54 PM
Member Group: Members Posts: 70 Joined: 12-February 06 From: Redwood City, CA Member No.: 5,569 |
Ok Guys,
I am really torn about this, but it looks like I will probably be buying a early long hood 911 in the next couple of weeks and can't fit more than two Porsches in my garage. Yes I could probably come up with some place to store the third car, but frankly I love just being able to walk out to my garage to look at and tinker on my cars whenever I want to. Having an offsite location for one of the cars just would not work for me. So in any event, this late 1970 Six (#2615) has been a part of my life for nearly 25 years now and has been a Northern CA car its entire life. During my entire ownership history I have also been incredibly anal about the care of this car, never ever driving it in the rain and, in fact, I am so paranoid about water that the car has only been washed twice the entire time I have owned it. On those two occasions I also made sure to use my air compressor to blow out ever little spec of water that may have gotten into in crevices in the car when washing. Since the car has always been garaged, it only ever gets a light layer of dust so all it takes to keep it clean is to wipe it down with a paraffin wax mop and some quick detailer spray. So aside from one tiny rust bubble right below the driver's side vinyl sail panel about this size of a small flat head nail that has never gotten any larger and would be a relatively easy repair, when I say no rust that truly is the case. When I bought the car way back in 1993 it had just been repainted in its original metallic green finish, a color that to me is just gorgeous. Yeaman Auto Body in Palo Alto did the repaint way back then and I dropped by Scott's shop about a year ago and he was blown away that the paint looked that good after all these years even with its minor road rash sustained over the years. The other real joy of this car to me is the 1985 3.2 Carrera motor I had installed by Henry Schmidt of Supertec back in 2002. The motor was not rebuilt as it was such a clean running engine with 70k miles then and still is. The engine now still only has approx. 90k miles at this time (less than 120k miles on the body). Goes to show you how little I have driven the car over the years, but the motor never fails me when I go out to the garage to fire it up after it may have been sitting for a month. Henry just cleaned it all up with new plug wires and engine shroud and mounted my original triple choke webers from my original 2 ltr power plant. It took some time to dial in the webers to the much larger motor, but after 6 hours on a dyno trying just the right combination of jets, it has run superbly ever since! Henry was also the one who fabricated the extremely unique exterior oil cooler location, mounting it right under the engine lid with a separate cut out in the panel of the metal with the same mesh screen inlaid over it. It works great and frankly am surprised that I have never seen such external cooling done in this way before or since. When the engine lid is closed, you hardly even notice anything out of the ordinary since it was so nicely integrated. We went this direction on the cooling as I was adamant about not making other holes in the body of the car to run an external cooler in the front bumper like what is usually done. Naturally I also kept my original unblemished engine lid and sourced another lid for this fabrication. And of course I still have my original motor stored safely in an enclosed crate ever since 2002! For those of you who have never driven a 6 with such substantially more horsepower, it is quite a rush to have more than double the original HP right behind you! The car also has original deep 6's. Not original to the car, but sourced many years ago during the early days of my ownership. It also still has its original six air cleaner housing in addition to the K&N filters with the water shield covers currently on the engine. The only other slight modification to the car are the very subtle slight flares on the rear fenders. This was done by a shop way before my ownership known as Metal Craft in the 70's. I've been told that apparently the process involves simply rolling the rear fender lips between two rollers to give it this perfectly symmetrical curve on each rear fender. I love it because it is so subtle it is barely noticed but allows for larger size tires if so desired. I am running 215's in the rear. So it is still all the original body metal, just slightly reshaped. In any event, I have been pretty long winded here talking glowingly about my car, but just wanted you all to know that I will be more earnest in marketing the car for sale in the coming weeks assuming the other Porsche acquisition occurs. I would describe the car as in very good driver condition and based on my high standards, I believe that's a very fair assessment. I'm sure that those who know my car in the Bay Area would vouch for this assessment as well. I have obviously not done any compression or leak down tests, but I am quite certain that anyone that ends up doing a PPI on this car will be very happy with such results. A couple last things I need to say. The car also retains its original H/E's that were ceramic coated years ago in a light grey factory looking finish and still look great today with no drips of oil on them. That's because the mid-80's Carrera motors are so oil tight! Below are a few pics of my trusty steed. |
stevesc_us |
Sep 25 2017, 11:15 AM
Didn't know you were installing a 3.2. In that case I would seriously consider removing the motronic fuel injection system entirely and going with the classic retro look EFI/ITB set up. Your engine bay would look much more like the engine would have come from the factory with the motor looking much less cluttered and clean looking.
I feel so strongly about this this that my potential 911 hot rod I may be buying also has a 3.2 motor in it that I plan on immediately converting to EFI/ITB's. Check out Al Kosmal's site http://www.x-faktory.com/contact.html for a gallery of engine porn with this great set up. The PMO ones look the most like the original webers. |
mepstein |
Sep 25 2017, 11:47 AM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Didn't know you were installing a 3.2. In that case I would seriously consider removing the motronic fuel injection system entirely and going with the classic retro look EFI/ITB set up. Your engine bay would look much more like the engine would have come from the factory with the motor looking much less cluttered and clean looking. I feel so strongly about this this that my potential 911 hot rod I may be buying also has a 3.2 motor in it that I plan on immediately converting to EFI/ITB's. Check out Al Kosmal's site http://www.x-faktory.com/contact.html for a gallery of engine porn with this great set up. The PMO ones look the most like the original webers. everybody has their own view to making the perfect 914. The 3.2 motronic engine is a super motor for our cars even if it doesn’t have the eye candy appeal of carbs. No matter how pretty you make the engine look, it hardly shows in a 914. Certainly much less than a 911. Even the fan faces the wrong way. Good luck with your hotrod build. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:22 PM |
