Wheel Spacers |
Wheel Spacers |
cal914 |
Sep 24 2017, 12:04 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
I want to put 25mm [1"] spacers on my front wheels of my GT conversion to bring the wheels out a bit further,if i were to put these on what if any problems could this cause to the car
Thanks Brian |
SixerJ |
Sep 24 2017, 01:10 PM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
porschetub |
Sep 24 2017, 01:38 PM
drifter914 |
Sep 24 2017, 05:53 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Four lug or five ? If you have a 5-stud conversion, you can use longer studs in the rotors & 1" slip over spacers. Not sure of supplier of spacers, but T3 Technique in Redmond, Wa has amazing supplies of wheel studs, bolts. 425.836.5983.
Best wishes... Terry |
Mike Bellis |
Sep 24 2017, 06:09 PM
Spacers on the front change the scrub radius. It will make it harder to steer at slow speeds and affect the high speed turning and centering slightly.
Google scrub radius for more info. |
Ed_Turbo |
Sep 24 2017, 06:30 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
No real problems if you choose a good spacer,I prefer H&R brand because they fit properly,end of story,you just don't cheap on parts like this,these are not cheap. Check your wheel bearing before fitting and torque them correctly to the hub,you will be good. (IMG:style_emoticons/default/agree.gif) |
porschetub |
Sep 25 2017, 02:45 PM
Four lug or five ? If you have a 5-stud conversion, you can use longer studs in the rotors & 1" slip over spacers. Not sure of supplier of spacers, but T3 Technique in Redmond, Wa has amazing supplies of wheel studs, bolts. 425.836.5983. Best wishes... Terry As an engineer the concept of studs that long concerns me,but that just me,I know people on here have done it and Porsche did it on the early 944 with the spacer they used in the rear of those cars. The 30mm H&R one I showed is actually a spacer adaptor,I prefer this type of design for the thicker spacers. |
Sep 25 2017, 03:02 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The 30mm H&R one I showed is actually a spacer adaptor,I prefer this type of design for the thicker spacers. Those are also illegal in most (if not all) racing organizations. Probably fine for street driving though. I have 100mm wheel studs on all 4 corners on my car with no ill effects. The long studs allow me to quickly change wheels and spacers of various sizes. (IMG:style_emoticons/default/bye1.gif) |
Sep 25 2017, 03:03 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
A friend of mine races his Cobra with 3β of spacers over extra long studs. Passes tech and no issues.
mgp4591 |
Nov 27 2017, 04:47 AM
914 Guru Group: Members Posts: 5,369 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
The 30mm H&R one I showed is actually a spacer adaptor,I prefer this type of design for the thicker spacers. Those are also illegal in most (if not all) racing organizations. Probably fine for street driving though. I have 100mm wheel studs on all 4 corners on my car with no ill effects. The long studs allow me to quickly change wheels and spacers of various sizes. (IMG:style_emoticons/default/bye1.gif) Andy, is that the total length of your wheel studs or the exposed length only? |
bdstone914 |
Nov 27 2017, 07:39 AM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I want to put 25mm [1"] spacers on my front wheels of my GT conversion to bring the wheels out a bit further,if i were to put these on what if any problems could this cause to the car Thanks Brian What exactly are they going onto? 911 aluminum hubs? From what I have seen Porsche only uses up to 19mm spacers with 65mm studs on spacers. With thicker spacers they go to the bolt on adapters. Consider if 19mm 944 spacers and studs will work. I have a set if you are interested. |
GeorgeRud |
Nov 27 2017, 08:31 AM
Drive a car with the increased scrub radius before spending the money - itβs not that much fun. Even the difference between 7β and the original 5 1/2β wheels is noticeable between my 914-6 and my GT flared conversion.
Chris914n6 |
Nov 27 2017, 02:03 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
From the flared cars I've driven, it makes the steering harder, but it's not bad unless you have girl muscles.
Nov 27 2017, 02:29 PM
914 Idiot Group: Members Posts: 14,983 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Those are also illegal in most (if not all) racing organizations. Probably fine for street driving though. Are you sure? The wording that I remember is "spacer that changes the bolt pattern". Spacers similar to the one above were used on the early 930s; hopefully those weren't problematic... --DD |
gms |
Nov 27 2017, 03:08 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I prefer this type (which require longer lug studs), they are from the 944 and readily available
Nov 27 2017, 03:18 PM
Those are also illegal in most (if not all) racing organizations. Probably fine for street driving though. Are you sure? The wording that I remember is "spacer that changes the bolt pattern". Spacers similar to the one above were used on the early 930s; hopefully those weren't problematic... The way i have always seen it worded is that any bolt on spacer is not permitted and i have actually never seen bolt on spacers that did *not* change the bolt pattern. (IMG:style_emoticons/default/idea.gif) |
Nov 27 2017, 09:48 PM
The ones shown above don't change it--it's still 5x130mm. They do rotate the pattern, of course...
--DD |
Mark Henry |
Nov 27 2017, 10:23 PM
From the flared cars I've driven, it makes the steering harder, but it's not bad unless you have girl muscles. Yeh... I told my wife that she's has been driving my 914 too much lately. (IMG:http://www.914world.com/bbs2/uploads_offsite/pbs.twimg.com-26-1511843022.1.jpg) |
porschetub |
Dec 1 2017, 08:01 PM
Those are also illegal in most (if not all) racing organizations. Probably fine for street driving though. Are you sure? The wording that I remember is "spacer that changes the bolt pattern". Spacers similar to the one above were used on the early 930s; hopefully those weren't problematic... --DD (IMG:style_emoticons/default/agree.gif) see no issue,extended studs well that's a risk the owner takes,people buy by cost on these ....price out genuine and see. The spacer I showed would be fine for the OP cause he won't need extended studs. |
RickS |
Dec 1 2017, 08:55 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Lo-Fi Version | Time is now: 9th May 2024 - 11:56 PM |
