Easy as 1 2 3, Got it yesterday, pushed all projects aside! |
mgphoto |
Sep 28 2017, 03:54 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Got the 123Ignition yesterday, I pushed all of my projects back!
"Sorry granny I'll get to those bearings on your heart/lung machine soon, I promise." Blocked out 3 hours for the removal and install. Added about an hour to charge the battery. Installed as expected, there is a spacer that is necessary for type 4, just slides over the dizzy shaft. I decided to route the wires and vacuum away from the fan so access to the vacuum nipple was easier, since the vacuum can is gone there's a lot more space. Followed the instructions but made the mistake of using the TDC 0* instead of the 27* as the basic timing point. I just walked the dizzy CCW until she started! Didn't do anything other than matched my timing with my idle, I let her run till she settled down. Just around the block once, ha ha the trailer hitching is GONE! Responsive throttle, man! Setting up a tuning session, nice 150 mile run up the California coast with the AFR meter. Mike |
Mblizzard |
Sep 29 2017, 10:50 AM
Really liked my 1 2 3. Did you get the programmable one?
I found the indicator on the switch exceptionally difficult to be sure which setting was selected but other than that it was flawless. I have the one with the electronic trigger points! |
mgphoto |
Sep 30 2017, 01:40 PM
Really liked my 1 2 3. Did you get the programmable one? I found the indicator on the switch exceptionally difficult to be sure which setting was selected but other than that it was flawless. I have the one with the electronic trigger points! I'm limited to the D-Jet version, after putting all the facts together I used the "B" setting 174 011 with vacuum retard only. |
Lo-Fi Version | Time is now: 18th May 2024 - 09:38 AM |
