Easy as 1 2 3, Got it yesterday, pushed all projects aside! |
mgphoto |
Sep 28 2017, 03:54 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Got the 123Ignition yesterday, I pushed all of my projects back!
"Sorry granny I'll get to those bearings on your heart/lung machine soon, I promise." Blocked out 3 hours for the removal and install. Added about an hour to charge the battery. Installed as expected, there is a spacer that is necessary for type 4, just slides over the dizzy shaft. I decided to route the wires and vacuum away from the fan so access to the vacuum nipple was easier, since the vacuum can is gone there's a lot more space. Followed the instructions but made the mistake of using the TDC 0* instead of the 27* as the basic timing point. I just walked the dizzy CCW until she started! Didn't do anything other than matched my timing with my idle, I let her run till she settled down. Just around the block once, ha ha the trailer hitching is GONE! Responsive throttle, man! Setting up a tuning session, nice 150 mile run up the California coast with the AFR meter. Mike |
VaccaRabite |
Oct 24 2017, 12:10 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Sounds like you are well on the way.
I hate electrical gremlins. So hard to track and fix. The low idle with headlights - did you fix that? That will not be helping you tune, and could be part of your issue. Could be dirty grounds (or dirty contacts raising resistance in your wire harness). If thats the issue, it could be pervasive. Have you considered taking the car to a dyno and having it tuned there? I was very slow to accept this, and Mark opened my eyes to it. I'm so sold on it now. Zach |
Lo-Fi Version | Time is now: 18th May 2024 - 07:54 AM |
