Easy as 1 2 3, Got it yesterday, pushed all projects aside! |
mgphoto |
Sep 28 2017, 03:54 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Got the 123Ignition yesterday, I pushed all of my projects back!
"Sorry granny I'll get to those bearings on your heart/lung machine soon, I promise." Blocked out 3 hours for the removal and install. Added about an hour to charge the battery. Installed as expected, there is a spacer that is necessary for type 4, just slides over the dizzy shaft. I decided to route the wires and vacuum away from the fan so access to the vacuum nipple was easier, since the vacuum can is gone there's a lot more space. Followed the instructions but made the mistake of using the TDC 0* instead of the 27* as the basic timing point. I just walked the dizzy CCW until she started! Didn't do anything other than matched my timing with my idle, I let her run till she settled down. Just around the block once, ha ha the trailer hitching is GONE! Responsive throttle, man! Setting up a tuning session, nice 150 mile run up the California coast with the AFR meter. Mike |
pete000 |
Oct 30 2017, 02:13 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
If the car did not ping with the stock distributor I would suspect the 123 unit is programmed more aggressively or just too much timing along of the curve.
Have you verified the advance with a timing light? A programmable timing light with RPM read out can help you determine where your at now through out the rpm range. The high octane will compensate for too much advance but at a high cost and inconvenience. VP Racing Fuels on Western Ave and PCH sells race gas in any configuration you would want. Have you verified fuel pressure? checking AFR would also be a good idea as you might be too lean which could lead to ping. I am curious as was there ping before the 123 unit? (IMG:style_emoticons/default/popcorn[1].gif) |
914_teener |
Oct 30 2017, 09:23 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
If the car did not ping with the stock distributor I would suspect the 123 unit is programmed more aggressively or just too much timing along of the curve. Have you verified the advance with a timing light? A programmable timing light with RPM read out can help you determine where your at now through out the rpm range. The high octane will compensate for too much advance but at a high cost and inconvenience. VP Racing Fuels on Western Ave and PCH sells race gas in any configuration you would want. Have you verified fuel pressure? checking AFR would also be a good idea as you might be too lean which could lead to ping. I am curious as was there ping before the 123 unit? (IMG:style_emoticons/default/popcorn[1].gif) Have you verified fuel pressure? checking AFR would also be a good idea as you might be too lean which could lead to ping. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 10:40 AM |
