Riveted Flares |
Riveted Flares |
Oct 3 2017, 02:39 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Removable flares really don't make the easier any easier to work on however, they do reduce bodywork required and can be installed without repainting the car. This last bit is a huge advantage. I can't tell in the pics but some fender welting / beading would help seal the flare so water does not splash through the seam. All told, you can have upwards of $4000 into welded on steel so rivit or bonded fiberglass starts to look really good as an alternative... It’s an alternative but a nicely done steel flare is a beautiful thing. |
ConeDodger |
Oct 3 2017, 02:53 PM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Removable flares really don't make the easier any easier to work on however, they do reduce bodywork required and can be installed without repainting the car. This last bit is a huge advantage. I can't tell in the pics but some fender welting / beading would help seal the flare so water does not splash through the seam. All told, you can have upwards of $4000 into welded on steel so rivit or bonded fiberglass starts to look really good as an alternative... It’s an alternative but a nicely done steel flare is a beautiful thing. Oh, I totally agree! Thank you McMark! (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Front yard mechanic |
Oct 3 2017, 03:04 PM
Senior Member Group: Members Posts: 1,172 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
More and more cars being flaired make the narrow cars worth more (IMG:style_emoticons/default/beerchug.gif)
DM_2000 |
Oct 3 2017, 05:04 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
The issue with fiberglass to steel is differing expansion rates that will eventually lead to cracking.
Have a look at my post 14 for bonding steel flares. http://www.914world.com/bbs2/index.php?showtopic=317169 |
Oct 3 2017, 05:35 PM
The issue with bonding on steel flares is that they are made to be welded. When a part is made to be bonded, the area that gets the glue is shaped differently. You can’t just lay the flare on the fender and apply glue. It would take a redesign of the flare and a way to flange the cut fender area. Same issues on the longitudinal reinforcements. It needs to be designed for adhesive from the ground up.
Larmo63 |
Oct 3 2017, 07:44 PM
In a couple more years, every 914 will be flared.
Mike Bellis |
Oct 3 2017, 08:48 PM
Lo-Fi Version | Time is now: 8th June 2024 - 06:13 PM |
