Engine Rebuild, 2.5L Six |
jfort |
Oct 4 2017, 09:18 AM
Senior Member Group: Members Posts: 1,135 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I doubt that there will be anything earth shattering or even beyond common knowledge, but if only to document this project, here goes:
This is a big, first time project for me, an attorney and mechanic wannabe. My factory six with a 2.5L engine was missing. Turns out there was only 75% compression in #1 and it was leaking through the inlet valve. Auto Assets in Powell OH diagnosed and my friend and mechanic, Jay Kjoller confirmed. Thankfully, Jay, an experienced air cooled engine builder and racer who lives nearby agreed to take on the project and to let me help. I got the engine out and delivered it to Jay last week. We started the disassembly yesterday. Learned some things about the engine. It has an early aluminum case with Mahle 90mm pistons and Nikasil cylinders. Pretty sure they are 2.7L. It has a later 3-ribbed oil pump, which Jay says is sufficient for what I do. The pistons have been lightened, which Jay said was unusual. We expected to see something that would explain the problem with #1. Other than some carbon accumulation on the head where the valve closes there was nothing. But, having gone this far, we decided to go from top end rebuild to a full rebuild and we split the case. Considerations. I think the engine was built into a 2.5 in the early 70's given SCCA classes at the time, but it is just a guess. My prior owner was Jim Chambers in Oregon. He bought the car in 2001 from Werks 2 in in Burbank CA, which was started a long ago by Harry Bieker (Bieker Engineering) and continued by his son, Galen Bieker. I exchanged emails with Galen but he couldn't remember any details that would help us decide how far to go on the rebuild. But Jay said whoever built it did a good job and he can recognize the approximate build date from the materials used, e.g., paper gaskets and 3 thin copper seals at the bottom of the cylinders. What I would call the wear points, (bearings, cam lobes, valve tappets, etc.) looked to be in good shape. But I wanted to be sure. Jays says he has had good experience with something other than the existing E cam, a Solex cam? that is a little more aggressive. So, we are going to either source that or investigate grinding the E cam. Friday, I will wash all the oily parts. Heads, valves, piston rods go to the machine shop, which is nearby. What can go into a hot bath tank will go there. What can be powder coated will go there. The air shroud, which is green, needs something. Not sure what to do about that. |
jd74914 |
Dec 6 2017, 04:13 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I believe you can also use Microsquirt now for 6 cylinder wasted spark control. It's a bit more expensive than Megajolt, but wouldn't require the super old EDIS components, or the specialized trigger of the SDS system. You'd just be running a few coils and basically whatever crank trigger you wanted.
A number of people on the Bird Board have been using Denso 90080-19016 COPs. They are relatively inexpensive on eBay and I believe have their own internal ignitors so you wouldn't need any coil drivers (**have to check my notes so this might not be 100% and they may need drivers**). Not the same look as the firewall mounted coils with long wires or 12 plug dizzy, but pretty clean/slick setup IMHO. Just some more things to think about. (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
Dec 6 2017, 08:43 PM
I believe you can also use Microsquirt now for 6 cylinder wasted spark control. It's a bit more expensive than Megajolt, but wouldn't require the super old EDIS components, or the specialized trigger of the SDS system. You'd just be running a few coils and basically whatever crank trigger you wanted. Yeh who wants to put that super old 90's EDIS tech on a car designed in the 60's. SDS comes with the trigger sensor and on a six it's fairly easy to do. And the Toyota COP's don't ignite by magic, guys that use them are often using MS and a missing tooth trigger setup. Or hall effect... or optical.... |
jd74914 |
Dec 7 2017, 03:40 AM
Yeh who wants to put that super old 90's EDIS tech on a car designed in the 60's. SDS comes with the trigger sensor and on a six it's fairly easy to do. And the Toyota COP's don't ignite by magic, guys that use them are often using MS and a missing tooth trigger setup. Or hall effect... or optical.... I get using EDIS 10-15 years ago, but now it seems like there are better options with more trigger flexibility since you need another controller anyways; getting rid of the EDIS module just removes part of the system if you use coils with built in ignitors. Like I said, just trying to give some more options. Obviously you need a trigger for any non-distributor system. It's pretty economical to run COP with an MS-based system and doesn't require a specific type of trigger like SDS. You could even likely use the SDS CDI you like with a COP setup. It doesn't have internal drivers to direct fire coils (as seen by the presence of the Hurco/Bosch ignitor modules on their website), so provided SDS allows you to tune dwell, you could wire any coils you wanted to the output of the ignitor module. |
Lo-Fi Version | Time is now: 7th May 2024 - 04:27 AM |
