Transmission Mounts, Are 911 mounts the same as 914? |
mmascari |
Oct 6 2017, 06:37 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Can someone tell me if the transmission mounts for the 911 are the same used for the 914? My local shop has some 911 in stock but I need them tomorrow.
ClayPerrine |
Oct 6 2017, 07:03 PM
Life's been good to me so far..... Group: Admin Posts: 15,455 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Can someone tell me if the transmission mounts for the 911 are the same used for the 914? My local shop has some 911 in stock but I need them tomorrow. Yes, the 911 mounts are the same as the transmission mounts on a side shifter 914, and both the transmission and engine mounts on a tail shifter 914. |
mmascari |
Oct 6 2017, 08:57 PM
Can someone tell me if the transmission mounts for the 911 are the same used for the 914? My local shop has some 911 in stock but I need them tomorrow. Yes, the 911 mounts are the same as the transmission mounts on a side shifter 914, and both the transmission and engine mounts on a tail shifter 914. Thank you! |
GeorgeRud |
Oct 6 2017, 09:52 PM
Actually, there are slight differences (even between 914-4 and 914-6) in the mounts, but they’ll work fine.
SirAndy |
Oct 7 2017, 09:47 AM
Resident German Group: Admin Posts: 41,634 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Actually, there are slight differences (even between 914-4 and 914-6) in the mounts, but they’ll work fine. (IMG:style_emoticons/default/agree.gif) I use the 911 sport engine mounts as transmission mounts for my sideshifter and you may have to take a dremel to the mounting holes to make them fit perfectly but other than that they work very well. (IMG:style_emoticons/default/smash.gif) |
ndfrigi |
Oct 7 2017, 10:20 AM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
arne |
Oct 7 2017, 10:21 AM
Serial Rescuer of old vehicles... Group: Members Posts: 737 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
This was good and timely info, thanks to all. I had replaced the front mounts in my '73 when I had the engine dropped, but didn't do the rears. Ive felt that the drivetrain still has a fair amount of rock on throttle changes, figured I should do the rear as well.
Years back, shortly after I bought the 911, I put 4 sport mounts in it. I discovered then that the mounts I took out were also sport mounts and were quite fresh. So I have spare 911 sport mounts on the shelf. I think a pair of them will go in the 914 this weekend. |
mmascari |
Oct 7 2017, 11:55 AM
Cool thanks for all the info. See how it works out later today.
Lo-Fi Version | Time is now: 13th May 2024 - 06:16 AM |
