| xsboost90 |
May 22 2005, 01:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
so im impressed that my new motor starts right up and runs. I put my hand in front of the exhaust to see what the temperature of the exhaust was to see- kinda- running rich/lean or what. I notice that #2 cylinder has no exhaust coming out. I check the plug, drowned. Well, my new plugs were stock plugs, so i switch them all out to the hotter plugs that came in the motor, #2 is drowned immediatly. I check spark, perfect. I check injector pulse, perfect. I did an experiment. I took the injector out, put in a new plug that was perfectly clean- drowned it after a brief start. Ok so where is this "gas" or liquid coming from. Im thinking the case is full of gas. Im scared to check the crankcase though. I have a ghetto compression tester, you push it in and hold it while someone cranks. #1 has like 110lbs roughly, #2 has 60-70lbs, 90lbs if you hold it there a couple seconds. IF my crankcase is full of gas-from cranking and cranking w/o ignition the last couple of days- and i drain it, any chance my compression will come back up and itll stop drowing plugs or do i need to take it back out and rebuild it already????? (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
| Joe Bob |
May 22 2005, 01:39 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Do the dance....check valve clearance, do a compression check at WOT...still low, throw in a tablespoon of 30 weight....compression comes up...it's the rings.
Change oil and run a straight 40 or 50 weight.....check again. You may have washed down the rings.... |
| Rusty |
May 22 2005, 01:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 7,994 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: South East States
You may have two problems. Start with the mechanical.
Did you adjust your valves? Even if you did, do it again. If #2 is too tight, you'll have low compression. Don't ask me how, my common sense tells me it should be the opposite... but that's how it works. -Rusty (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) |
| Allan |
May 22 2005, 01:46 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
If you can, just take a quick look down the throttle body into the plenumn. You might be suprised to see a pool (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) of raw fuel sitting in it. Ask Scott, Joe, Aaron, Matt and Clayton how I know.
| Aaron Cox |
May 22 2005, 01:47 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
lots of gas in the cylinders means bad things on new engines......
it can dilute the lubricating quality of the oil and the rings wont seat (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) have you drained your oil yet? |
| xsboost90 |
May 22 2005, 03:19 PM
well, the engine was built and the guy ran it for about 1500 miles- one year before i bought it. He decided to go w/a hotter motor and i bought it. I adjusted the valves but thats not to say i didnt do something wrong somehow.
| xsboost90 |
May 22 2005, 08:54 PM
ok, so while checking to make sure the valve adjustment i did was correct, i noticed that the #2 valve rocker "log" was about a quarter inch from the head and both nuts were gone. I guess the PO forgot to tighten that one. Then i thought about it, he had taken that one off for his other motor, and had to put another set of rockers on the day i bought the motor, but they checked the valve adjustment so i figured they had at least tightened the rockers. I went ahead and double checked the rest of them. and my adjustments for them. Everything is AOK and now i have exhaust coming out the tailpipe on all four. Also drained the oil. or should i say the gas w/ a touch of oil. Flushed it out repeatedly and refilled w/ some rotella 15w40 and a new filter. Finally time to start on important things like seats!
cpt tripps, if your still willing to come help w/ the car this weekend im all for it! I need all the help i can get at this point. Going to try and get the parts all painted this week. Attached image(s)
| Allan |
May 22 2005, 08:57 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Way to go.... Now move on to the next issue and beat it!!! We WILL meet up at the WCC '06!!!!!
Keep the faith. |
| Joe Bob |
May 22 2005, 09:00 PM
Change the oil and look to see if there is any gas in it....
Lo-Fi Version | Time is now: 12th July 2026 - 01:35 PM |
