914 clock repair?, reasonable recommendation |
drem914 |
Oct 7 2017, 05:03 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Just purchased a clock as part of group of center console gauges online from someone that said it was working when they pulled the console out. It was the only one of the three (volt and temp) that was not all scratched up. It was completely frozen. Now I have 2 that don't work (IMG:style_emoticons/default/headbang.gif)
I went to North Hollywood Speedo and they said "Service on these can range from $195 to $385. 1-5 day turn around." I don't need a clock that bad.... Anyone have recommendation for a reasonable repair on the center console clock? (later model) |
drem914 |
Oct 9 2017, 09:47 PM
The hands, for the original one, that is still in the car,, work smoothly and i swapped the bulb to an LED bulb and lit up nicely under power. i was hoping to avoid taking a clock apart (I did that once when I was a kid and that did not go very well) and just swap the replacement in and walk away. The hands on the one I received will not even turn. It appears to be seized up and I doubt will work. I will try to take that one apart first and see if the pelican fix works. If not, then I'll see what I do with the other. thanks for the recommendations and options
North Coast Jim |
Sep 15 2018, 07:43 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
The hands, for the original one, that is still in the car,, work smoothly and i swapped the bulb to an LED bulb and lit up nicely under power. i was hoping to avoid taking a clock apart (I did that once when I was a kid and that did not go very well) and just swap the replacement in and walk away. The hands on the one I received will not even turn. It appears to be seized up and I doubt will work. I will try to take that one apart first and see if the pelican fix works. If not, then I'll see what I do with the other. thanks for the recommendations and options If you push the minute hand too deep on the post it will hit the gauge face mounting screw, hence no more movement. Take it out and investigate that first. It happens |
Lo-Fi Version | Time is now: 16th May 2024 - 09:01 PM |
