Group buy air deflector for cooling. Change airflow under the car, $28 A set. |
Mikey914 |
Oct 9 2017, 07:32 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
As mentioned we've been working on these for some time. Just getting to finishing these up.
They change the airflow to help cool the engine better. $28 A set who's in? |
raynekat |
Oct 10 2017, 02:17 PM
Advanced Member Group: Members Posts: 2,154 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Yeah what do these things do? 4 or 6 cylinder?
GregAmy |
Oct 10 2017, 04:11 PM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Yeah what do these things do? 4 or 6 cylinder? If you look under your car, attached to the bottom of the firewall (or, well, supposed to be) are two little air deflectors that hang down. They're supposed to be hanging down from the firewall. The purpose of these are to - duh - deflect under-body air downward and create negative pressure behind them, under the cylinders. Due to this negative pressure the positive pressure at the top of the cylinders will cause air to flow faster/better downward through the cylinders and heads, improving cooling. If you don't have these, you really should. It's actually surprising how effective they are. Edit: found a photos online. It's that black deflector at the bottom of the photo: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.aircoolednut.com-15565-1507673728.1.jpg) |
Lo-Fi Version | Time is now: 26th April 2024 - 04:34 PM |
