Group buy air deflector for cooling. Change airflow under the car, $28 A set. |
Mikey914 |
Oct 9 2017, 07:32 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
As mentioned we've been working on these for some time. Just getting to finishing these up.
They change the airflow to help cool the engine better. $28 A set who's in? |
raynekat |
Oct 10 2017, 02:17 PM
Advanced Member Group: Members Posts: 2,154 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Yeah what do these things do? 4 or 6 cylinder?
Mikey914 |
Oct 11 2017, 06:11 AM
Yeah what do these things do? 4 or 6 cylinder? They weren't on the 6 as it was before their time. So from a concurs standpoint no. They will "work" on all. The idea is that the air is flowing past the opening where the engine compartment is and has been directed parallel for at least the 5-6' prior. So these are mounted at he firewall to create a low pressure area on the engine side. The hot air is sucked down and airflow is disrupted. The "vortex generators"are technically a wing-let that allows for more low pressure to build (a more efficient "wing"), and works at a lower airspeed. Honestly, the improvement I have made may only make the part 2-3% more effective (as it does in aircraft). So mine will not be 20% cooler than stock but there is data so show it is an improvement (at least on the aircraft side). Also we can easily shave these off for the CW should you you be in that crowd (and yes I do lean that way, but not a card carrying member). Hope this helps with the concept and thanks for posting the pics up!. |
bbrock |
Oct 11 2017, 08:02 AM
Yeah what do these things do? 4 or 6 cylinder? They weren't on the 6 as it was before their time. So from a concurs standpoint no. They will "work" on all. The idea is that the air is flowing past the opening where the engine compartment is and has been directed parallel for at least the 5-6' prior. So these are mounted at he firewall to create a low pressure area on the engine side. The hot air is sucked down and airflow is disrupted. The "vortex generators"are technically a wing-let that allows for more low pressure to build (a more efficient "wing"), and works at a lower airspeed. Honestly, the improvement I have made may only make the part 2-3% more effective (as it does in aircraft). So mine will not be 20% cooler than stock but there is data so show it is an improvement (at least on the aircraft side). Also we can easily shave these off for the CW should you you be in that crowd (and yes I do lean that way, but not a card carrying member). Hope this helps with the concept and thanks for posting the pics up!. The amazing thing about this forum is that the answers come before I even have to ask the question. Thanks Mark! Definitely in for a set. |
Lo-Fi Version | Time is now: 25th April 2024 - 09:43 PM |
