Momo parts quality?, have they gone to the dogs |
porschetub |
Oct 9 2017, 08:54 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
(IMG:style_emoticons/default/stromberg.gif) is my only description of the wheel hub I bought off a Momo dealer on ebay.
Following issues; 914 VDM horn contact ring won't fit correctly, hub spline is too thick,hub nut not fully on column shaft thread, hub earths on steering column,without spacer on shaft. Contacted the seller and he claims to have stated the stock horn contact ring may not fit in his auction,nothing to that effect,checked it,its so far out the cancel piece is a long way out from being centre on the RH side. No where on the box is "made in Italy",the instructions say so but these could be easily copied,really thinking its a Chinese "knock off",anyone had this issue. Vent over ok...anyone else had this issue. TIA |
NeunEinVier |
Oct 13 2017, 11:46 AM
Member Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None |
Buying on Amazon is only safer than eBay if you're actually buying FROM Amazon corporate.
If you're buying from an Amazon seller, you're getting the same stuff that's on eBay, but paying two to five times the price. If it's something like USB cables or little electronics from China, you might as well check the reviews on Amazon and then buy the exact same item directly from an eBay seller in China or Taiwan. The item might have a different brand name, but you can tell by the appearance if it's the same item or not. |
Lo-Fi Version | Time is now: 5th May 2024 - 06:32 PM |
