Wish me luck |
Wish me luck |
spare time toys |
May 22 2005, 05:32 PM
Im going to replace the ring and pinion in the Suburban myself. Been reading the manuals and it just seems to be alot of close tolerances. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) No big deal we deal with that all the time at work. Worst case is I screw up and it costs me what they wanted to do it at a shop to fix my goof (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
skline |
May 22 2005, 05:38 PM
Ok, Good Luck, I dont think you will need it, I am sure you will do just fine.
Allan |
May 22 2005, 06:03 PM
Good luck. Sounds like you have the experience to do most anything based on what you have done to a 914
ClayPerrine |
May 22 2005, 07:36 PM
Life's been good to me so far..... Group: Admin Posts: 15,462 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Done lots of them.. If you run into a problem, let me know. I can help.
Joe Bob |
May 22 2005, 07:50 PM
Easy....done a lot of them. The smell of the gear oil sucks.....bring beer. Have gud jack stands and consider doing the rear brakes at the same time....
spare time toys |
May 26 2005, 05:42 PM
Well this has turned to shit (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) The ring and pinion I got is the same as what I am taking out. It had a 3.73 in it all ready (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) All the bearings are trashed out and the housing looks to be OK (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) The bearings are stuck on the carier and I broke a puller trying to get them off. The stinking thing would not fit in the press at work. A guy at the rebuilder I got the bearing kit from said start with all the old shims in it with the new parts that way you are close to where it needs to be. Im taking the carier to a local shop to get the bearings off tomorow. I was suposed to haul a bunch of kids to play paintball in it this weekend (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) OH well that aint gonna happen (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Joe Bob |
May 26 2005, 05:44 PM
Ummm, hope this isn't a stoopid question....but why didn't ya just buy a whole USED pumpkin from the bone yard and just slam it in?
spare time toys |
May 26 2005, 05:51 PM
The lowest priced one I could find was $1000. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) I got the R&P for $80 and the overhaul kit for $90. The used one had 20000 more miles than what I have on mine and I have new brakes. |
Joe Bob |
May 26 2005, 05:53 PM
WOW...prices HAVE gone up.....last one I got was 200 bucks. Now that I think about...it was before I was married. A long time ago in a galaxy far....oh hell you know what I mean.
Joe Bob |
May 26 2005, 05:55 PM
Wait one....$1K for axle to axle or for just the internal part for the rear end?
spare time toys |
May 26 2005, 05:57 PM
That was for one brake to brake with the junkyard guarntee if it was bad bring it back and try another. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
Joe Bob |
May 26 2005, 06:06 PM
OK,,,that's different. If the rear end went, why replace the whole axle? Did it crack the rear end carrier?
Last one I did, I popped the axles out, dropped the drive shaft and popped out the pumpkin.... |
spare time toys |
May 26 2005, 06:19 PM
Carrier is OK. If I get the bearings off with out throwing this thing across the drive that is. Easy to get out, take off pinion mut, take the cover off, take brakes off, unhook sway bar and panhard bar, pop out C clips shove axels out remove bearing caps, center pops out, then pound out pinion. With clean up only took about 2 hours in all. Now back together We will see (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Cap'n Krusty |
May 26 2005, 07:00 PM
You're gonna let a buncha kids play paintball in it? You don't need a new R&P, you need a new brain! LOL, The Cap'n, just SEEING the picture in his head! |
spare time toys |
Jun 1 2005, 07:54 AM
Update on the saga of my rear end..... Its done (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I have a little howl in it but not much more than it had before. The gear paint patern looked OK and I moved the shims around untill it would be worse if they went in another way. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) So the gas hog is back on the road (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Lo-Fi Version | Time is now: 14th May 2024 - 03:25 PM |
