v82go |
Resident Contrarian ![]() ![]() Group: Members Posts: 249 Joined: 9-December 04 From: Lakeland, Fl. Member No.: 3,250 ![]() |
for sale: a 915 to small block chevy (early) adapter plate with flywheel and some
hardware. Flywheel surface looks good (slight surface rust) it all could use a good cleaning. This setup uses a pull type 911 clutch. It was installed in a "76" 911 I purchased, I also have the engine to 911 body mount and alternator with brackets for a 911. I would assume that the adapter plate/flywheel would work for a 914/915 with flipped ring gear. I believe it to be Rod Simpson stuff Adapter plate w/flywheel and hardware asking $250 plus shipping 911 body to SBC motor mount with pictured alternator and brackets (brackets bolt on to the front of a SBC in the water pump area as pictured. $100 plus shipping Or everything for $300 plus shipping (yes its heavy) Local pickup welcome 33809 the last couple of pictures show how it mounted in the 911 Attached thumbnail(s) ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 4th July 2025 - 01:27 AM |
