for sale: a 915 to small block chevy (early) adapter plate with flywheel and some
hardware. Flywheel surface looks good (slight surface rust) it all could use a good
cleaning. This setup uses a pull type 911 clutch. It was installed in a "76" 911
I purchased, I also have the engine to 911 body mount and alternator with brackets
for a 911. I would assume that the adapter plate/flywheel would work for a 914/915
with flipped ring gear. I believe it to be Rod Simpson stuff
Adapter plate w/flywheel and hardware asking $250 plus shipping
911 body to SBC motor mount with pictured alternator and brackets (brackets bolt on to the front of a SBC in the water pump area as pictured. $100 plus shipping
Or everything for $300 plus shipping (yes its heavy) Local pickup welcome 33809
the last couple of pictures show how it mounted in the 911
