My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Oct 15 2017, 02:40 PM
I spent this morning doing a little house cleaning. When the Hell Hole wall was patched it was done so using 3-4 smaller pieces that were welded together with lap joints. Not the prettiest but functional. I had seen this in the photos posted prior to buying the car. Before I reattached the flare I decided to take a look under some very thick undercoating and found Mr. Ugly staring back at me! There is also another small patch closer to the front that you can see in the after pics. Glad I looked or this would have needed another repair in a few years.
I cleaned the metal with a wire brush on my grinder then primed the recessed and exposed areas as well. Next I filled the voids and lap joints with Wurth's Seam Sealer followed up with 2 coats of primer. Doesn't look like 3 hours work but it was. Also took a good pic of the block casting # So. it's a Head casting ID but I haven't lifted a valve cover to get the casting # So apparently it's "G" which is a 350 head. Will the 350 mate to a 327?. That's why the casting number will be more accurate. I guess it's possible that some modification was done. |
Lo-Fi Version | Time is now: 4th May 2024 - 07:14 AM |
