My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
rhodyguy |
Oct 16 2017, 07:14 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Be pointed forward when you go for the first big throttle stab. Steep and fast learning curve. Be prepared for the hot gun that thinks they want to challenge the poser in the flared 914.
76-914 |
Oct 16 2017, 06:47 PM
Be pointed forward when you go for the first big throttle stab. Steep and fast learning curve. Be prepared for the hot gun that thinks they want to challenge the poser in the flared 914. That won't happen for awhile Kev. Renegade is very explicit about breaking in the clutch sold with that kit. 500 miles of normal stop and go driving before you can punch it. That works out to be about $150-$200 of Petro. I bought a sand blaster kit recommended by another member about 6 months ago and finally got to use it today. OMG, what a (IMG:style_emoticons/default/sheeplove.gif) difference from that POS HF gun. I purchased a cabinet and gun from HF and that SOB put me in a bad mood every time I used it. It had a mind of it's own and would work then not work. I would shake the cabinet, change media, cuss, threaten it, pray, stir the sand, unclog the pick up tube, take the gun a part, you name it. This kit was made to modify the HF set up (you think they know it is a POS) and came with a big pick up hose, a beefy pick up tube and larger pistol with 3 different size metal tips. IIRC, it was about $60 and worth every penny. All it does is work, very well, every time you pull the trigger. To give you and idea, in 20 minutes of cleaning this afternoon I've blown the paint off the back wall of the cabinet. It never came off in the 2 years that I used it with HF's gun. Life is once again good! (IMG:style_emoticons/default/piratenanner.gif) A pic showing 5 minutes work. Only did 1/2 of each piece to illustrate. |
Lo-Fi Version | Time is now: 4th May 2024 - 09:47 AM |
