My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Oct 14 2017, 05:30 PM
Must be 108 if both you guys agree. I couldn't access the R side as well so I pulled the flare I found the holes for the flare were drilled after it was painted so I sanded/cleaned and primed the bare metal spots where it was drilled out and on the cut line as well. While I was at it I did the same on the left side and for a gash on the rear trunk lid. That spot will be covered by a Ducktail spoiler so it will probably just get some bondo filler later.
Attached image(s) |
barefoot |
Oct 19 2017, 05:43 AM
Senior Member Group: Members Posts: 1,271 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Lo-Fi Version | Time is now: 4th May 2024 - 06:36 AM |
