My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Oct 22 2017, 05:15 PM
I'm working on "how to" use the existing 914 throttle cable. I fished the cable reasonably close to the carb to see if it would reach. There wasn't any place to connect the cable on the carb linkage so I drilled out that small tab that is bent at a 45 degree angle then straightened that tab out to accept the barrel adapter that I had laying around.
After fitting the barrel to the linkage I cut the end off the cable and fit it inside the barrel. Next I heated that stiff plastic sheathing to bend it towards the carb. I made this bracket to hold the cable in place. I couldn't bend this bracket to 90 degrees or the barrel would contact it before it reached maximum pull i.e. full throttle but at this angle the cable was pointing up and would bind. I placed another bend in the bracket to level it out. seems to line up alright so next step is to remove this old cable and replace it with a new one. |
Lo-Fi Version | Time is now: 4th May 2024 - 10:01 AM |
