My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Oct 28 2017, 09:40 PM
Finally got a chance to work on Red today. Finished mounting the radiator but still need to fab the plenum and mount the fans. That'll have to wait until I get up to Aircraft Spruce for some aluminum. Guess I should start plumbing it in the meantime. (IMG:style_emoticons/default/idea.gif)
Installed some of the "Bling" that came with the car My clutch pedal now stands on it's own since I connected the clutch And my acellarator now functions. The old cable was toast so I put a new one in. I used one that I had ordered for Kugal when I converted it to a Suby 6 but they made it wrong so they gave it to me. Well guess what; it fit Red perfectly. (IMG:style_emoticons/default/biggrin.gif) The only thing I need to do now is attach the pedal but that would just be in the way at this stage. |
Lo-Fi Version | Time is now: 4th May 2024 - 12:41 PM |
