My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Nov 2 2017, 08:23 PM
Made the rough cut templates out of cardboard. They give me a general idea of the size to cut the second set out of poster board which is easier to bend and fit.
Then the poster board templates are fit and trimmed. Bottom piece checked in place Then the sides and top pieces are cut, trimmed and clecoed in place Next I riveted the bottom to the frame but can't rivet the remaining pieces in because the right side headlight harness passes thru and I haven't checked out the electrical yet. Reinstalled the radiator to check fit |
Lo-Fi Version | Time is now: 4th May 2024 - 05:10 AM |
