My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Nov 9 2017, 08:50 AM
Got'a keep moving if I want to sell this thing in time for Spring Fever. One good thing about posting the pic's is you have a chance to review your work. I just noticed that I have my radiator lines bass-akwards. (IMG:style_emoticons/default/chair.gif) An easy fix no harm done.
While waiting for the paint to dry on the shroud I worked up the courage to remove the windshield. It was held in place by approximately 11 tubes of silicon. (IMG:style_emoticons/default/lol-2.gif) Once I was able to open up an area large enough to fish a wire through I was able to slice thru it. This will give you an idea of how much silicon needs to be removed. I fashioned the scraper out of some 1/2" PVC conduit and gave it an edge. It works well. I removed about a 3rd of the caulking in 5 minutes as you can see in this pic. There is a small skim coat that remains in the channel so I'm thinking what would be the smart approach to remove it. Maybe a brass bristle roto brush chucked in a drill so the rpm's aren't high enough to bubble the paint Then mask and prime the area if any paint comes of during the process? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 11:58 AM |
