My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Nov 9 2017, 08:09 PM
Yeah Chris, When I get after it I will remove that pillar trim for sure. Tonite I was able to get 99% of it off to the point it is basically a skim coat. I think one of those eraser wheels that body men use to remove decals might be the ticket. What are those called Chris? No problem Bob. I spent more time whining about it than it's taken to remove it! (IMG:style_emoticons/default/happy11.gif) Keeping it dry was priority #1.
Lo-Fi Version | Time is now: 4th May 2024 - 11:29 AM |
