My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Nov 9 2017, 10:16 PM
That's it Stephan. But it's about 3/16" too wide. Damnit. You've put me on the right trail though. I wonder if I could wear it down on the sides w/o much trouble. That channel is only about 8mm wide some places. There are some spray n adhesive removers too but I'm doubtful they'd breakdown silicon. (IMG:style_emoticons/default/idea.gif) I see they also make plastic razor blades for safe scrapping. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 4th May 2024 - 02:29 AM |
