My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
bulitt |
Nov 10 2017, 06:10 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Wire wheel for a dremel?
76-914 |
Nov 10 2017, 08:41 AM
Wire wheel for a dremel? Yea Bob, I'm thinking along those lines but a softer brass one and something I can chuck into a die grinder. Dremel tools are fine for tiny stuff but this is about 12'. Did I mention that their terribly overpriced, as well. (IMG:style_emoticons/default/mad.gif) Next on the schedule is flushing the block. (IMG:style_emoticons/default/beerchug.gif) |
914_teener |
Nov 10 2017, 08:45 AM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Wire wheel for a dremel? Yea Bob, I'm thinking along those lines but a softer brass one and something I can chuck into a die grinder. Dremel tools are fine for tiny stuff but this is about 12'. Did I mention that their terribly overpriced, as well. (IMG:style_emoticons/default/mad.gif) Next on the schedule is flushing the block. (IMG:style_emoticons/default/beerchug.gif) Jeez Kent, impressed with your sheet metal work. Cleeco's and everything. Your wife must be a Saint. |
Lo-Fi Version | Time is now: 4th May 2024 - 01:48 AM |
