My '70 V-8 Assembly Thread, a few updates and pic's |
76-914 |
Oct 14 2017, 02:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb? The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Dec 16 2017, 07:40 PM
I've decided to complete this 914 w/o a radio. Got to thinking about it and Tony has a point. Besides, I wouldn't be able to hear it anyway. (IMG:style_emoticons/default/lol-2.gif) Can someone post a pic and dimensions for a radio block off plate so I can make one. TIA Kent (IMG:style_emoticons/default/beerchug.gif)
Chris914n6 |
Dec 16 2017, 08:57 PM
Jackstands are my life. Group: Members Posts: 3,310 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I've decided to complete this 914 w/o a radio. Got to thinking about it and Tony has a point. Besides, I wouldn't be able to hear it anyway. (IMG:style_emoticons/default/lol-2.gif) Can someone post a pic and dimensions for a radio block off plate so I can make one. TIA Kent (IMG:style_emoticons/default/beerchug.gif) I have used a DIN size pocket/storage bin. Like one would see under the stereo of a 90s Japanese car. (IMG:style_emoticons/default/idea.gif) The pocket from a 968/944 will work too with a little plastic trimming, plus it has a clock that sometimes works. |
Lo-Fi Version | Time is now: 4th May 2024 - 02:02 AM |
