Brake lights stopped working |
57lincolnman |
Oct 15 2017, 11:01 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
Brake lights went out. Turn signals and emergency flashers still work so I don't think it's the fuse. Bulbs are OK. Could it be the brake switch? Kind of scary driving without brake lights, so the car is in the garage until I can sort this out. Thoughts anyone?
oakdalecurtis |
Oct 15 2017, 11:31 PM
Oakdalecurtis Group: Members Posts: 1,327 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
If you look at the attached electrical diagram and code sheet, you will see in row 51 that the brake switch is powered by the same lead that goes to your reverse lights (gray/brown stripe in row 52, M16 and M17). If your reverse lights work, you are getting power to your brake switch(F). If you are getting power to the switch but not to the brake lights, M2 and M4, I would conclude that you need a new switch. With the brake light switch depressed, check that you have power on the black/yellow stripe wire where it leaves the switch (54) to make sure it is the switch that is defective, and not a wire problem to the brake lights themselves.
Lo-Fi Version | Time is now: 21st May 2024 - 02:59 AM |
