Bed liner in the cabin? |
mb911 |
Oct 16 2017, 01:39 PM
914 Guru Group: Members Posts: 6,855 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I really want to spray a bed liner inside the cabin but don't want anything that won't set up hard.. I plan to epoxy prime then bed liner og sorts then color.. Any suggestions? I don't want it to smell in the end.. Any thoughts?
Mikey914 |
Oct 16 2017, 06:26 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We plan to use bed liner mainly because we plan to drive the car. That paint chips easier so rather than have to worry about ever doing anything under there again why not protect it?
I certainly don't want to use rubberized undercoating. |
DM_2000 |
Oct 16 2017, 06:39 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
I certainly don't want to use rubberized undercoating. Spray in bed liner isn't far away from rubberized undercoat. If you are not planning on driving the car in salt / snow, Rustolem and a brush works just fine under the car. It drys soft, is pretty chip resistant and is easy to touch up. On cars that see any salt duty, I use Rusfre rust proofing black under car and tan for enclosed surfaces. The black skins over but stays soft unlike undercoating and the tan remains soft. Besides, you will need to inspect and touch up bed liner once in a while as the coating is bound to crack at the seams, hold water and start to rust. |
Lo-Fi Version | Time is now: 24th May 2024 - 02:16 PM |
