Bed liner in the cabin? |
Rand |
Oct 16 2017, 08:27 PM
If you really know you aren't creating moisture traps. Go for it!
amfab |
Oct 16 2017, 09:29 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
I am planning—if I ever get the rust repair done—Epoxy Primer then Upol Raptor tinted to Ivory White for the underneath and lizard skin sound for the inside of the passenger compartment and lizard skin sound and lizard skin heat for the engine side of the firewall. Ivory white paint over the lizard skin
mlindner |
Oct 17 2017, 04:53 AM
Senior Member Group: Members Posts: 1,516 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
mb911 |
Oct 17 2017, 05:24 AM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
tygaboy |
Oct 17 2017, 08:46 AM
914 Guru Group: Members Posts: 5,285 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I am planning—if I ever get the rust repair done—Epoxy Primer then Upol Raptor tinted to Ivory White for the underneath and lizard skin sound for the inside of the passenger compartment and lizard skin sound and lizard skin heat for the engine side of the firewall. Ivory white paint over the lizard skin Exactly what I'm planning! Well, except for the Ivory White part... (IMG:style_emoticons/default/poke.gif) |
amfab |
Oct 17 2017, 10:26 AM
I am planning—if I ever get the rust repair done—Epoxy Primer then Upol Raptor tinted to Ivory White for the underneath and lizard skin sound for the inside of the passenger compartment and lizard skin sound and lizard skin heat for the engine side of the firewall. Ivory white paint over the lizard skin Exactly what I'm planning! Well, except for the Ivory White part... (IMG:style_emoticons/default/poke.gif) Awesome, you can let me know how it works—I am so far behind and my girlfriend just bought a fixer upper (house) that means bathrooms and a kitchen remodel before I get back to my car |
mlindner |
Oct 17 2017, 05:20 PM
Hey Ben, if your going to run flared fenders, come see me and I can show you the brackets I made and give you some templates. Best, Mark
DM_2000 |
Oct 17 2017, 05:55 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
I make pickup truck wheel liners from dirt track racer plastic, it comes in 2 ft wide rolls and in many colors. Use a heat gun to warm the plastic ( it takes a while over a large area ) and you can bend and form.
This is great for the rear wheel wells as a simple U shape bolted to the bed flange works wonders. |
Rand |
Oct 17 2017, 06:03 PM
Covered moisture traps lead to the worst kind of rust... the hidden cancer.
mb911 |
Oct 17 2017, 06:32 PM
mb911 |
Oct 17 2017, 06:47 PM
Rand |
Oct 17 2017, 06:51 PM
Bautiful car MB. Is there bedliner in it?
mb911 |
Oct 17 2017, 07:02 PM
Bautiful car MB. Is there bedliner in it? (IMG:style_emoticons/default/biggrin.gif) Nope but it had that texture from the factory on the underside.. Thats kind of what I am after.. |
Oct 17 2017, 07:45 PM
Resident German Group: Admin Posts: 41,618 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
mb911 |
Oct 17 2017, 07:56 PM
Seems there are lots of thoughts. Probably going to rethink and wait until primer on and make a decision.. |
Rand |
Oct 17 2017, 08:07 PM
QUOTE Seems there are lots of thoughts. Probably going to rethink and wait until primer on and make a decision.. Enough has been said. Just don't. Drop in some removable rubber floor panels if you feel the need to capture your girlfriend's spilled drink or try and stop some sound. Take them out otherwise! |
malcolm2 |
Oct 17 2017, 08:14 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I used that stuff as the final coat on my sails and the removable Long covers. I used flat black and by design it kinda spits small thick specks. From 10' my sails look like factory.
burton73 |
Oct 17 2017, 09:49 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I remember this stuff that cars had in there trunks in the 60s when I was small. It was called Zolatone and it was very durable and they had a lot of great colors. Spatter Paint
Bob B Zolatone AIM Multicolor Midnight Blue - 20 Series Stock Color Spatter Finish, 1 Gallon Item #: ZOL 20-84-1 The Perfect OEM Finish The Perfect Coating To Refinish Anything You Can Imagine Fabulous Looking Tough Performing Zolatone 20 Multicolor Spatter Finishes Zolatone is a durable coating that resists wear from abrasion scratching and chipping Far tougher than regular paint November 24, 2012 Despite the trunk bodywork being finished for a long time, I only recently got around to laying down some spatter paint. When it comes to spatter paint, you can either get the stuff in the rattle cans, or you can get quart cans made by a company called Zolatone and spray it with your own gun. I've seen rattle can jobs and they look nice, but the spots seem to be very fine and the texture is very heavy, so I thought I'd try the Zolatone stuff. I bought a quart of the Black/Aqua Zolatone which I believe is correct for '67 Pontiacs. |
amfab |
Oct 17 2017, 10:22 PM
I used a zolatone product on an equipment rack once. The stuff I used was just the bumpy bits, with no color—the bits were black and the liquid part was clear, You sprayed or brushed it on and then topcoat it with color. It was a very weird application—I did it with a brush—but very durable and professional looking. it was similar to the targa top finish. They make a few different products I don't remember which one this was.
tygaboy |
Oct 18 2017, 07:36 AM
You all have me thinking...
I'm nearing the point where I'll be having my chassis blasted and epoxy coated. I'm thinking I may test out a couple of these products on the chassis to see how it turns out and decide which I like...then send it off to have it all removed! I used this Eastwood "trunk paint" on another car and really liked how it turned out. One thing I have to account for is that I have no trunk floor so my entire engine compartment/trunk area is exposed to heat and road grime so I'll need something that's "reasonably easy" to clean. Eastwood does call out that this "must be sealed with Diamond Clear for Painted Surfaces". I guess I can do that then dirty it all up and see how it tidies up. I'll certainly keep you posted on how it goes. Attached image(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 06:17 AM |
