WTB-Parts |
WTB-Parts |
partwerks |
Oct 16 2017, 10:08 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
WTB-Parts
1. I need two good used belt mouldings that have the outer fuzzy strip to keep the window from rattling. 2. Clips for horizontal sail panel trim. I only have 3 of the arrow shaped clips, so whatever the balance is to mount the two trim pieces. 3. Clips and bolts/nuts, for the two sail panel pieces that has the curve in it. 4. Need the clips for the horizontal moulding that is just below the back/rear of the roof that is a trim piece on the rollbar. I have only one clip, so would need however many to mount it. 5. On one headlight, I need that offset/dogleg piece, and the bolt to mount it. Also, just around the corner is a triangular shaped tab that has 3 allen head bolts that mount it. |
GaroldShaffer |
Oct 17 2017, 08:10 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I should be able to help you with all of those items. PM sent.
Mikey914 |
Oct 17 2017, 10:07 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Got new tracks and fuzzies here -
http://shop.914rubber.com/91453195910-Door...m?categoryId=-1 Also the fuzzes and even more stuff you may need. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:08 AM |
