MSD Install - tach not working -, wiring help please |
David Mueller |
May 23 2005, 12:31 PM
Member Group: Members Posts: 79 Joined: 4-February 03 From: Calgary, Alberta Canada Member No.: 236 |
I could use some help with the wiring on my MSD 6AL -
I have a Blaster coil, MSD dizzy and the MSD8910 tach adaptor - I've attached a picture of how it hooked up. Not showing is the MSD 8910 tach adaptor - it only has two wires going to it. A red and a white - the red is spliced into light gauge red wire coming out of the MSD which is hooked to ingintion trigger 12V - the white wire I have connected to the single wire I have running up to my tach but it doesn't work. I used to have an optical pick-up with a stock 009 dizzy and everything worked fine..since I went to the MSD dizzy I can't get the tach to work.. Any idea's? Engine runs fine, just can't get a reading off the tach... Any help would be appreciated. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Attached thumbnail(s) |
iamchappy |
May 23 2005, 12:45 PM
Ive always used the 8920 tach adapter without problems but others on the board have used the 8910 and were able to get it to work with some dinking around, I just replied to a post a few days ago and they had the same problems with the 8910 but a few showed how you can wire it to make it work.
iamchappy |
May 23 2005, 12:51 PM
Lo-Fi Version | Time is now: 21st May 2024 - 11:27 AM |
