I could use some help with the wiring on my MSD 6AL -
I have a Blaster coil, MSD dizzy and the MSD8910 tach adaptor -
I've attached a picture of how it hooked up.
Not showing is the MSD 8910 tach adaptor - it only has two wires going to it. A red and a white - the red is spliced into light gauge red wire coming out of the MSD which is hooked to ingintion trigger 12V - the white wire I have connected to the single wire I have running up to my tach but it doesn't work.
I used to have an optical pick-up with a stock 009 dizzy and everything worked fine..since I went to the MSD dizzy I can't get the tach to work.. Any idea's?
Engine runs fine, just can't get a reading off the tach...
Any help would be appreciated.
