Opinions on this 75 1.8L? |
iwanta914-6 |
Oct 18 2017, 08:59 AM
Senior Member Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None |
I know my history with getting interested in a 914 and then not being able pull the trigger, but I would appreciate some input on this little 75 1.8L not far from where I live. Apparently originally an Arizona car. I don't have any pictures of the hell hole or longs, but I kind of want to go take a look at it. I contacted the seller and received some additional pictures. It supposedly is in running condition.
Click for pictures You can see in the pictures that the battery has been relocated, probably because the battery tray rotted away, but no pictures of that area were given to me. Does anything else jump out at you in the pictures that would be of concern? Thanks. |
Larmo63 |
Oct 18 2017, 09:43 AM
Other than the ugly rear trunk, it looks pretty solid from underneath.
tygaboy |
Oct 18 2017, 10:04 AM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I'd bet you have enough info to make the call so if after you check it out, you feel the price is right, I vote you buy it, jump in and join the adventure.
Two things to remember: 1. Everything is fixable 2. Life is short |
bbrock |
Oct 18 2017, 10:05 AM
Like you said, you really need to see what is underneath the rocker covers. Picture 20 looks like there could be some significant rust lurking under there. You already noted the battery relocate and lack of hell hole pics. You can see there is still a battery tray in place, but can't tell the condition. I'd also want to probe the rear seam of that trunk to make sure it is solid. IMO, replacing the rear section of trunk is not a big deal, but you would want to know if it needs to be done. The only other thing I see is it looks like somebody crunched the frunk with a floor jack maybe. That's not hard to bang back out though.
But it seems like the car is worth at least taking a look at. |
Mueller |
Oct 18 2017, 10:09 AM
I like the 1.8 motors with the L-Jet, building one right now!
JOEPROPER |
Oct 18 2017, 10:20 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I think it's worth taking a ride to see it. You've been around long enough to know the problem areas and current values, so take a look. How bad can it be? (IMG:style_emoticons/default/lol-2.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 03:09 PM |
