Refinishing: Magnesium Fan Shroud & Transmission Case, Need Advice |
914_7T3 |
Oct 19 2017, 01:21 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,848 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
In reading up on some older threads, it has been stated that the Fan Shroud & Transmission Cases are Magnesium.
I have the shroud out for media blasting along with the engine tin etc.... Once completed should the shroud be finished with a high heat clear paint such as a Krylon that is rated up to 600 degrees. Also should there be any type of prep done between these steps. I want it to look right, but do not know if they were coated from the factory or should be left in the original finish. On that note the transmission case will not be blasted, but it was suggested that it be cleaned up with a wire brush and steel wool. Is that the correct way to go and similar to the shroud does it require a clear painted finish or just leave it alone. Here is a pic of a small section that I went over with steel wool after degreasing. Lastly, once the Muffler is blasted, does that require a high heat ceramic coating? If I do not coat it, will that just accelerate any future surface corrosion? Don't really want to spend 1/2 the value of a new muffler heat coating the old one. Any advice? |
Dr Evil |
Oct 19 2017, 01:43 PM
I cannot speak to the shroud as I do not know what they left the factory with, but the case for the trans had Tectyl coating on it. It was a corrosion preventative, but it wore off in a few months from what I have read/been told. I have never bought any or reapplied it. The product that many like is called Gibbs, I don't have a link available currently. It last longer. However, from my personal experience on the rare occasion that I do clean and paint a case, I just used good quality spray paint of what ever desired color and finish I wanted and it has been fine. The key is that you do want to protect the trans case, particularly if you are anywhere there is salt, or wet environments. I am originally from San Diego and lived in PA and OH and the East coast stuff is way more corroded than the West coast on average.
914_7T3 |
Oct 19 2017, 01:49 PM
The key is that you do want to protect the trans case, particularly if you are anywhere there is salt, or wet environments. I am originally from San Diego and lived in PA and OH and the East coast stuff is way more corroded than the West coast on average. Thanks Doc, forgot to mention that the car upon completion will be a bit of a garage Queen. She won't come out in the rain...ever and hope not to have to drive through any puddles. (IMG:style_emoticons/default/lol-2.gif) |
Elliot Cannon |
Oct 19 2017, 01:59 PM
Paint it black. (IMG:style_emoticons/default/biggrin.gif)
TheCabinetmaker |
Oct 19 2017, 02:04 PM
I've cleaned and polished a few shrouds. They don't last without a protective coating, and most clear coats don't hold well either. I spray them with an industrial enamel the same color as the grey intake runners. They stay very nice that way.
914_7T3 |
Oct 19 2017, 02:14 PM
"I wanna see it painted, painted black Black as night, black as coal I wanna see the sun blotted out from the sky I wanna see it painted, painted, painted, painted black" However, trying to keep it original looking. |
porschetub |
I have seen fan housing done a flat silver (alloy look) paint after blasting....looks pretty good IMO,I honestly didn't know they were made from magnesium ,always thought they were alloy (IMG:style_emoticons/default/confused24.gif) .
I wouldn't use a wire brush or wire wool on the trans case because you will burnish metal particles into the surface of the magnesium ,use the 3m green pads and their wheels you can put on a drill or die grinder,prep the surface super clean then put your chosen clearcoat on. Good luck. |
cal44 |
Oct 19 2017, 02:56 PM
Member Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region |
As the others mentioned.......wire brush?.....NO
Like Dr. Evil I'm also from San Diego.......wait......I still live here. Bronze wool, I use fine grade. It's a secret weapon few car guys know about. The boating pros use the bronze as it doesn't rust when tiny particles are not cleaned up and puts a smooooth finish to the surface. It does wonders on old chrome, doesn't dig in to aluminum either. Been using it for decades. If you can't find it locally, order on line and make sure to shop the price, wide variations. As for coatings, PRO clear can spray, Rustoluem clear. We just did a '66 Bronco Roadster that had all original factory chalk marks thru out. We did five layers of Rustoleum clear. It had a very low gloss and the marks are now safe and quite visible. Por-15 is supposed to have a crystal clear coating but I have yet to give it a go. Do not use Por-15 clear rust sealer. We use Kano Labs degreaser as our first step. |
mgphoto |
Oct 19 2017, 03:05 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
altitude411 |
Oct 19 2017, 04:08 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
That fan shroud looks great (IMG:style_emoticons/default/shades.gif) Here is my trans getting the treatment... lots of elbow grease to remove road grime.
Attached thumbnail(s) |
mb911 |
Oct 19 2017, 04:22 PM
914 Guru Group: Members Posts: 6,839 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
mgphoto |
Oct 19 2017, 04:49 PM
That fan shroud looks great (IMG:style_emoticons/default/shades.gif) Here is my trans getting the treatment... lots of elbow grease to remove road grime. Beautiful! But you're gonna cover the surface with the wax Dr. E talked about? |
Oct 19 2017, 04:53 PM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
mgphoto |
DM_2000 |
Oct 19 2017, 05:01 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
Paint would be fine. On steel wheels I've used machine gray then before it drys, dusted stainless over top to give a slight bit of sparkle ( both were Rustoleum in a spray can. ) The gray was too bland , stainless too bright. Argent is a common wheel color but that was a bit too bright.
mb911 |
Oct 19 2017, 05:51 PM
Very nice, I love the look. Did you do it yourself, rattle can? I sprayed it with my sata automotive sprayer. I have a bunch more paint. If anyone needs something sprayed. |
mb911 |
Oct 19 2017, 06:09 PM
eric914 |
Oct 20 2017, 11:07 AM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
I did a little digging on what the aircraft and marine industry uses and ended doing the final wash on the raw case with Prekote surface pretreatment then priming with Zinc Chromate primer. Not sure what ill do for a top coat yet.
Dr Evil |
Oct 20 2017, 12:57 PM
I did a little digging on what the aircraft and marine industry uses and ended doing the final wash on the raw case with Prekote surface pretreatment then priming with Zinc Chromate primer. Not sure what ill do for a top coat yet. Man, you are gonna be done pretty quick tomorrow as the cleaning is the longest part. I remember zinc chromate when I was working on aircraft and ships. The MSDS made it look like really nasty stuff. Should protect very well. |
iankarr |
Oct 20 2017, 01:07 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Wow...nice to have a spotless case. Took me 8 hours with a toothbrush and mineral spirits to get mine clean.
I used "alumi-blast" paint by Seymour. Here's a link... https://www.amazon.com/Seymour-16-055-Alumi...t/dp/B003V5BPKU |
Lo-Fi Version | Time is now: 10th May 2024 - 09:18 PM |
