914_7T3
Oct 19 2017, 01:21 PM
In reading up on some older threads, it has been stated that the Fan Shroud & Transmission Cases are Magnesium.
I have the shroud out for media blasting along with the engine tin etc....
Once completed should the shroud be finished with a high heat clear paint such as a Krylon that is rated up to 600 degrees. Also should there be any type of prep done between these steps. I want it to look right, but do not know if they were coated from the factory or should be left in the original finish.
On that note the transmission case will not be blasted, but it was suggested that it be cleaned up with a wire brush and steel wool. Is that the correct way to go and similar to the shroud does it require a clear painted finish or just leave it alone. Here is a pic of a small section that I went over with steel wool after degreasing.
Click to view attachmentClick to view attachmentLastly, once the Muffler is blasted, does that require a high heat ceramic coating? If I do not coat it, will that just accelerate any future surface corrosion? Don't really want to spend 1/2 the value of a new muffler heat coating the old one.
Any advice?
Dr Evil
Oct 19 2017, 01:43 PM
I cannot speak to the shroud as I do not know what they left the factory with, but the case for the trans had Tectyl coating on it. It was a corrosion preventative, but it wore off in a few months from what I have read/been told. I have never bought any or reapplied it. The product that many like is called Gibbs, I don't have a link available currently. It last longer. However, from my personal experience on the rare occasion that I do clean and paint a case, I just used good quality spray paint of what ever desired color and finish I wanted and it has been fine. The key is that you do want to protect the trans case, particularly if you are anywhere there is salt, or wet environments. I am originally from San Diego and lived in PA and OH and the East coast stuff is way more corroded than the West coast on average.
914_7T3
Oct 19 2017, 01:49 PM
QUOTE(Dr Evil @ Oct 19 2017, 12:43 PM)
Thanks Doc, forgot to mention that the car upon completion will be a bit of a garage Queen. She won't come out in the rain...ever and hope not to have to drive through any puddles.
Elliot Cannon
Oct 19 2017, 01:59 PM
Paint it black.
TheCabinetmaker
Oct 19 2017, 02:04 PM
I've cleaned and polished a few shrouds. They don't last without a protective coating, and most clear coats don't hold well either. I spray them with an industrial enamel the same color as the grey intake runners. They stay very nice that way.
914_7T3
Oct 19 2017, 02:14 PM
QUOTE(Elliot Cannon @ Oct 19 2017, 12:59 PM)
Paint it black.
"I wanna see it painted, painted black
Black as night, black as coal
I wanna see the sun blotted out from the sky
I wanna see it painted, painted, painted, painted black"
However, trying to keep it original looking.
porschetub
I have seen fan housing done a flat silver (alloy look) paint after blasting....looks pretty good IMO,I honestly didn't know they were made from magnesium ,always thought they were alloy
I wouldn't use a wire brush or wire wool on the trans case because you will burnish metal particles into the surface of the magnesium ,use the 3m green pads and their wheels you can put on a drill or die grinder,prep the surface super clean then put your chosen clearcoat on.
Good luck.
cal44
Oct 19 2017, 02:56 PM
As the others mentioned.......wire brush?.....NO
Like Dr. Evil I'm also from San Diego.......wait......I still live here.
Bronze wool, I use fine grade. It's a secret weapon few car guys know about.
The boating pros use the bronze as it doesn't rust when tiny particles are not cleaned up and puts a smooooth finish to the surface. It does wonders on old chrome, doesn't dig in to aluminum either. Been using it for decades. If you can't find it locally, order on line and make sure to shop the price, wide variations.
As for coatings, PRO clear can spray, Rustoluem clear. We just did a '66 Bronco Roadster that had all original factory chalk marks thru out. We did five layers of Rustoleum clear. It had a very low gloss and the marks are now safe and quite visible.
Por-15 is supposed to have a crystal clear coating but I have yet to give it a go.
Do not use Por-15 clear rust sealer.
We use Kano Labs degreaser as our first step.
mgphoto
Oct 19 2017, 03:05 PM
Sand blasted my fan shroud than power coat silver.
altitude411
Oct 19 2017, 04:08 PM
That fan shroud looks great
Here is my trans getting the treatment... lots of elbow grease to remove road grime.
Click to view attachmentClick to view attachmentClick to view attachment
mb911
Oct 19 2017, 04:22 PM
Click to view attachment This is cerakote on magnesium.. It is a ceramic paint.. Very durable..
mgphoto
Oct 19 2017, 04:49 PM
QUOTE(altitude411 @ Oct 19 2017, 03:08 PM)
Click to view attachmentClick to view attachmentClick to view attachmentBeautiful!
But you're gonna cover the surface with the wax Dr. E talked about?
Oct 19 2017, 04:53 PM
QUOTE(mb911 @ Oct 19 2017, 06:22 PM)
We’ve been using it more and more at the shop. You do need a real respirator to spray it. Strong stuff.
mgphoto
QUOTE(mb911 @ Oct 19 2017, 03:22 PM)
Very nice, I love the look.
Did you do it yourself, rattle can?
DM_2000
Oct 19 2017, 05:01 PM
Paint would be fine. On steel wheels I've used machine gray then before it drys, dusted stainless over top to give a slight bit of sparkle ( both were Rustoleum in a spray can. ) The gray was too bland , stainless too bright. Argent is a common wheel color but that was a bit too bright.
mb911
Oct 19 2017, 05:51 PM
QUOTE(mgphoto @ Oct 19 2017, 02:53 PM)
I sprayed it with my sata automotive sprayer. I have a bunch more paint. If anyone needs something sprayed.
mb911
Oct 19 2017, 06:09 PM
Here are my valve covers sprayed as well..
eric914
Oct 20 2017, 11:07 AM
I did a little digging on what the aircraft and marine industry uses and ended doing the final wash on the raw case with Prekote surface pretreatment then priming with Zinc Chromate primer. Not sure what ill do for a top coat yet.
Dr Evil
Oct 20 2017, 12:57 PM
QUOTE(eric914 @ Oct 20 2017, 01:07 PM)
Click to view attachmentMan, you are gonna be done pretty quick tomorrow as the cleaning is the longest part. I remember zinc chromate when I was working on aircraft and ships. The MSDS made it look like really nasty stuff. Should protect very well.
iankarr
Wow...nice to have a spotless case. Took me 8 hours with a toothbrush and mineral spirits to get mine clean.
I used "alumi-blast" paint by Seymour. Here's a link...
https://www.amazon.com/Seymour-16-055-Alumi...t/dp/B003V5BPKU
Oct 20 2017, 01:21 PM
Playing with cerakote at the shop.
mgphoto
Oct 20 2017, 02:07 PM
QUOTE(mepstein @ Oct 20 2017, 12:21 PM)
Talk about bling!
Big heavy chain and you can go clubbing!!
Mueller
Oct 20 2017, 02:14 PM
Dang, that looks good!
burton73
Oct 20 2017, 02:22 PM
914_7T3
Oct 20 2017, 07:43 PM
Thanks for chiming in everyone and the photos look great. Will be going ceramic titanium on the Muffler.
Spoke to a high end 911 restorer earlier today and confirmed that brass wool is the way to go on the transmission case. Also learned that media blasting may be too harsh for the fan shroud so I now have a line on someone that can do tumble blasting that is more gentle.
Here's the kicker, the recommendation is not to coat the magnesium with any paint or clear finish, but to liberally spray it with WD-40 for a natural finish and leave it alone.
As good as all of the painted photos look, I will go with the unfinished look.
Oct 20 2017, 08:04 PM
Gibbs works better than WD-40 for longevity.
914_7T3
Oct 20 2017, 09:49 PM
Here are some photos of the case from the 76 911 SC that sold at Gooding in Scottsdale this January for $93K
914_teener
Oct 20 2017, 09:51 PM
QUOTE(914 7T3 @ Oct 20 2017, 06:43 PM)
I saw no harm and couldn't think of any on powder coating the fan shroud. I brass wheeled the trans case and used Gibbs as described keep the mag from corroding. The trans gets hot so I didn't want any insulation to inhibit radiation of heat away from it.
It's probably not much but with air cooled motors every little bit helps.
worn
Oct 21 2017, 04:09 AM
QUOTE(eric914 @ Oct 20 2017, 09:07 AM)
Click to view attachmentThat is what I chose. From aircraft spruce.
toolguy
Oct 21 2017, 09:27 AM
You should look into Boshield T-9 from Boeing as
a preservative for bare Magnesium. Just saying. . .
rgalla9146
Oct 21 2017, 11:52 AM
Nothing screams 'beware' louder than a brightly painted VW or Porsche engine or trans.
Applying a legitimate preservative ? that's another story.
I do like the Cerakote on Bens valve covers. Perfect for magnesium wheels.
Oct 21 2017, 01:06 PM
QUOTE(rgalla9146 @ Oct 21 2017, 01:52 PM)
Rory secretly covets our chrome trans.
raynekat
Oct 21 2017, 09:24 PM
Ben, your valve covers look super.
What did you paint them with?
QUOTE(mb911 @ Oct 19 2017, 05:09 PM)
rgalla9146
Oct 22 2017, 06:13 AM
QUOTE(mepstein @ Oct 21 2017, 03:06 PM)
Ok, Ok, Mark I'll admit it. It looks good.
IronHillRestorations
Oct 22 2017, 02:38 PM
Media blast with walnut shells, clean with solvent, paint with high temp clear or unobtrusive gray/silver/cast metal high temp paint.
Bright silver looks great! .....on a VW sand rail or Meyers Manx.
Rav914
Oct 22 2017, 04:35 PM
QUOTE(914 7T3 @ Oct 20 2017, 08:49 PM)
Wait? What? $93K?
For a '76S?
Guberif
Oct 23 2017, 12:44 PM
New to this and can't figure out how to upload compressed pics. Still too big i guess. If you want you can just pm me and I'll email you my pics.
I got mine shining like a diamond! with no paint, but yet still protected.
Anyway, I just did both the fan shrouds, trany, h.e.'s & some select heater ducting last summer with good old fashioned elbow grease, dremmel with buffing pads, die grinder with several soft scotch brite pad, mothers polish seemed to work the best out of the 6 different types of polish I had tried, mothers polishing cone to get in on all the nooks and crannies and toothbrushes and a flexible narrow putty knife! I protected mine with diamond clear from eastwood, (father was a chemist) this stuff is relatively high temp and especially formulated for bare metal.
