> Refinishing: Magnesium Fan Shroud & Transmission Case, Need Advice
914_7T3
post Oct 19 2017, 01:21 PM
Post #21
In reading up on some older threads, it has been stated that the Fan Shroud & Transmission Cases are Magnesium.
I have the shroud out for media blasting along with the engine tin etc....
Once completed should the shroud be finished with a high heat clear paint such as a Krylon that is rated up to 600 degrees. Also should there be any type of prep done between these steps. I want it to look right, but do not know if they were coated from the factory or should be left in the original finish.
On that note the transmission case will not be blasted, but it was suggested that it be cleaned up with a wire brush and steel wool. Is that the correct way to go and similar to the shroud does it require a clear painted finish or just leave it alone. Here is a pic of a small section that I went over with steel wool after degreasing.
Attached ImageAttached Image
Lastly, once the Muffler is blasted, does that require a high heat ceramic coating? If I do not coat it, will that just accelerate any future surface corrosion? Don't really want to spend 1/2 the value of a new muffler heat coating the old one.
Any advice?
914 7T3   Refinishing: Magnesium Fan Shroud & Transmission Case   Oct 19 2017, 01:21 PM
Dr Evil   I cannot speak to the shroud as I do not know what...   Oct 19 2017, 01:43 PM
914 7T3   The key is that you do want to protect the trans...   Oct 19 2017, 01:49 PM
Elliot Cannon   Paint it black. :D   Oct 19 2017, 01:59 PM
914 7T3   Paint it black. :D "I wanna see it pai...   Oct 19 2017, 02:14 PM
The Cabinetmaker   I've cleaned and polished a few shrouds. They ...   Oct 19 2017, 02:04 PM
porschetub   I have seen fan housing done a flat silver (alloy...   Oct 19 2017, 02:14 PM
cal44   As the others mentioned.......wire brush?.....NO ...   Oct 19 2017, 02:56 PM
mgphoto   Sand blasted my fan shroud than power coat silver....   Oct 19 2017, 03:05 PM
altitude411   That fan shroud looks great :shades2: Here is my ...   Oct 19 2017, 04:08 PM
mgphoto   That fan shroud looks great :shades2: Here is my...   Oct 19 2017, 04:49 PM
mb911   This is cerakote on magnesium.. It is a ceramic...   Oct 19 2017, 04:22 PM
mepstein   This is cerakote on magnesium.. It is a cerami...   Oct 19 2017, 04:53 PM
mgphoto   This is cerakote on magnesium.. It is a cerami...   Oct 19 2017, 04:53 PM
mb911   This is cerakote on magnesium.. It is a ceram...   Oct 19 2017, 05:51 PM
DM_2000   Paint would be fine. On steel wheels I've use...   Oct 19 2017, 05:01 PM
mb911   Here are my valve covers sprayed as well..   Oct 19 2017, 06:09 PM
raynekat   Ben, your valve covers look super. What did you pa...   Oct 21 2017, 09:24 PM
eric914   I did a little digging on what the aircraft and ma...   Oct 20 2017, 11:07 AM
Dr Evil   I did a little digging on what the aircraft and m...   Oct 20 2017, 12:57 PM
worn   I did a little digging on what the aircraft and m...   Oct 21 2017, 04:09 AM
cuddyk   Wow...nice to have a spotless case. Took me 8 hour...   Oct 20 2017, 01:07 PM
mepstein   Playing with cerakote at the shop.   Oct 20 2017, 01:21 PM
mgphoto   Playing with cerakote at the shop. Talk about ...   Oct 20 2017, 02:07 PM
Mueller   Playing with cerakote at the shop. Dang, that ...   Oct 20 2017, 02:14 PM
burton73   https://www.cerakotehightemp.com/testing/ Testing...   Oct 20 2017, 02:22 PM
914 7T3   Thanks for chiming in everyone and the photos look...   Oct 20 2017, 07:43 PM
914_teener   Thanks for chiming in everyone and the photos loo...   Oct 20 2017, 09:51 PM
mepstein   Gibbs works better than WD-40 for longevity.   Oct 20 2017, 08:04 PM
914 7T3   Here are some photos of the case from the 76 911 S...   Oct 20 2017, 09:49 PM
toolguy   You should look into Boshield T-9 from Boeing as ...   Oct 21 2017, 09:27 AM
rgalla9146   Nothing screams 'beware' louder than a bri...   Oct 21 2017, 11:52 AM
mepstein   Nothing screams 'beware' louder than a br...   Oct 21 2017, 01:06 PM
rgalla9146   Nothing screams 'beware' louder than a b...   Oct 22 2017, 06:13 AM
Perry Kiehl   Media blast with walnut shells, clean with solvent...   Oct 22 2017, 02:38 PM
Rav914   Here are some photos of the case from the 76 911 ...   Oct 22 2017, 04:35 PM
Guberif   New to this and can't figure out how to upload...   Oct 23 2017, 12:44 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:42 PM
