Help! Marelli dist install in a 914-6, How to install a Marelli dist |
skier2.0 |
Oct 20 2017, 04:13 PM
Newbie Group: Members Posts: 34 Joined: 30-May 14 From: United States Member No.: 17,422 Region Association: MidAtlantic Region |
I can't remember (I'am an old F#%$) and can find any info on reinstalling a Marelli in a 6. The manual only shows a Bosch. It says to get TDC Z1 piston #1, rotor arm must point to approximately in the direction of the rear edge of the blower. Then turn the dist housing left until points just open. The rotor arm should then be vertically over the notch on the dist housing.
The Marelli has no notch? Do I just get #1 piston to TDC ZL1 and point the rotor at #1 wire on the cap. Thanks in advance,Rick |
bretth |
Oct 20 2017, 04:39 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I have one on my 2.2 but it hasn't been run in very long time. But it is still installed. Let me know if there is anything on mine that may help id the alignment of yours that I can take a pic of.
porschetub |
Oct 20 2017, 11:36 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
You got it ,that's the only way really IF you haven't moved the engine from TDC @ #1,otherwise you will have to find TDC @ that point to refit.
When you refit you will notice the shaft will turn away from #1 as you push it down,this is because of the angle on the teeth of the drive gear,you will need to move it 1 tooth back of forward to get alignment. Good luck. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:16 PM |
