WTB Heater lever for center console..., Straight, not with the bend, including the red grip knob... |
MikeInMunich |
Oct 21 2017, 04:01 PM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Please send me a PM if you have one and your price.
Thanks! M.i.M. |
abes914 |
Oct 21 2017, 04:23 PM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
I have one. Will send you a picture tomorrow. Please pm me your email address so I can send pictures
GaroldShaffer |
Oct 21 2017, 06:34 PM
(IMG:style_emoticons/default/blink.gif) The heater lever for the center console is the bent one. The straight one is for non console cars. So Mike does your car have a center console? Or does it have a center deposit or none? If center deposit or non then it should be the straight lever. The bent one is used with consoles to line up with the hole in the base cover of the console.
bdstone914 |
Oct 22 2017, 06:53 AM
(IMG:style_emoticons/default/blink.gif) The heater lever for the center console is the bent one. The straight one is for non console cars. So Mike does your car have a center console? Or does it have a center deposit or none? If center deposit or non then it should be the straight lever. The bent one is used with consoles to line up with the hole in the base cover of the console. (IMG:style_emoticons/default/agree.gif) I have either type. I do not remember you cat having a console when I worked on it. And didn't you eliminate the ventilation system? Finding it a little chilly in Deutschland ? Bruce |
MikeInMunich |
Oct 22 2017, 10:45 AM
(IMG:style_emoticons/default/blink.gif) The heater lever for the center console is the bent one. The straight one is for non console cars. So Mike does your car have a center console? Or does it have a center deposit or none? If center deposit or non then it should be the straight lever. The bent one is used with consoles to line up with the hole in the base cover of the console. I have a center console and the "bent" lever. It doesn't line up with the slot properly, so I figured I have the wrong lever. My straight lever broke. Replacement was "bent". Straight lever was however original to the car and the console isn't. I can post a photo, later / soon. |
MikeInMunich |
Oct 22 2017, 10:49 AM
(IMG:style_emoticons/default/blink.gif) The heater lever for the center console is the bent one. The straight one is for non console cars. So Mike does your car have a center console? Or does it have a center deposit or none? If center deposit or non then it should be the straight lever. The bent one is used with consoles to line up with the hole in the base cover of the console. (IMG:style_emoticons/default/agree.gif) I have either type. I do not remember you cat having a console when I worked on it. And didn't you eliminate the ventilation system? Finding it a little chilly in Deutschland ? Bruce Hi Bruce! Correct, but this is for my black car, which is in my avatar photo here. Btw. it was a stupid idea to eliminate the heat completely from the white car. I drive with my heat on almost all the time over here, not to mention the fact that it would be nuts to not have it on with the top down on almost ANY evening of the year, much less in April, September or October. That car will be getting a new engine sometime soon and when it does, the heat is going back in, albeit without the blower onto the windshield, because it was deleted and would be a huge PITA to replace. Ed closed the slots for the vents entirely! (IMG:style_emoticons/default/blink.gif) M. |
GaroldShaffer |
Oct 22 2017, 12:48 PM
(IMG:style_emoticons/default/blink.gif) The heater lever for the center console is the bent one. The straight one is for non console cars. So Mike does your car have a center console? Or does it have a center deposit or none? If center deposit or non then it should be the straight lever. The bent one is used with consoles to line up with the hole in the base cover of the console. I have a center console and the "bent" lever. It doesn't line up with the slot properly, so I figured I have the wrong lever. My straight lever broke. Replacement was "bent". Straight lever was however original to the car and the console isn't. I can post a photo, later / soon. Mike I sent you a email with pictures of the proper lever for a console. The picture you sent me looks to be a straight one that someone bent to try and make work. Here is what the lever looks like (ignore the rust on them) Attached image(s) |
MikeInMunich |
Oct 22 2017, 12:53 PM
(IMG:style_emoticons/default/blink.gif) The heater lever for the center console is the bent one. The straight one is for non console cars. So Mike does your car have a center console? Or does it have a center deposit or none? If center deposit or non then it should be the straight lever. The bent one is used with consoles to line up with the hole in the base cover of the console. I have a center console and the "bent" lever. It doesn't line up with the slot properly, so I figured I have the wrong lever. My straight lever broke. Replacement was "bent". Straight lever was however original to the car and the console isn't. I can post a photo, later / soon. Mike I sent you a email with pictures of the proper lever for a console. The picture you sent me looks to be a straight one that someone bent to try and make work. Here is what the lever looks like (ignore the rust on them) When it's mounted, is the kink to the left, as in the photos, or to the right? Seems to me it must be to the right, no? |
McMark |
Oct 22 2017, 01:33 PM
To the right.
You may have a 'custom' console bottom plate. Not uncommon for people to make their own. They don't realize there's two different arms, and don't have the correct one, so they just make a new bottom plate, instead of finding the right part. |
Lo-Fi Version | Time is now: 20th May 2024 - 08:28 PM |
