Oil Pressure sender hose blew out, need help |
rgolia |
Oct 23 2017, 09:51 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
So last night the hose from the engine to the oil pressure sender blew out and sent oil everywhere. fortunately I was about 1 mile from home. Lot of oil everywhere, hopefully I did not fry the engine. of course to figure that out I need to get a new sender in place. I would like to have a sender that works the green idiot light and can also work a gauge and of course I would rather not have a hose after this incident. Any suggestions on the sender type and where to get it and what to expect when i try to restart the car...after adding oil of course! (IMG:style_emoticons/default/sad.gif)
pete000 |
Nov 13 2017, 01:05 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Here is the kit I got from a Miata MX5 performance site. Nice SS hose and fittings.Clamp included.
Attached thumbnail(s) |
Dave_Darling |
Nov 13 2017, 02:45 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Here is the kit I got from a Miata MX5 performance site. Nice SS hose and fittings.Clamp included. Hopefully you have added a ground wire to the outside of the sender. The insulation on the clamp will otherwise interfere with the ground path for the sender, and you're either going to get no readings, or inconsistent ones. --DD |
pete000 |
Nov 13 2017, 04:21 PM
Here is the kit I got from a Miata MX5 performance site. Nice SS hose and fittings.Clamp included. Hopefully you have added a ground wire to the outside of the sender. The insulation on the clamp will otherwise interfere with the ground path for the sender, and you're either going to get no readings, or inconsistent ones. --DD Works fine the hose is metal so the ground is there. |
Lo-Fi Version | Time is now: 20th May 2024 - 11:09 AM |
