Oil Pressure sender hose blew out, need help |
rgolia |
Oct 23 2017, 09:51 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
So last night the hose from the engine to the oil pressure sender blew out and sent oil everywhere. fortunately I was about 1 mile from home. Lot of oil everywhere, hopefully I did not fry the engine. of course to figure that out I need to get a new sender in place. I would like to have a sender that works the green idiot light and can also work a gauge and of course I would rather not have a hose after this incident. Any suggestions on the sender type and where to get it and what to expect when i try to restart the car...after adding oil of course! (IMG:style_emoticons/default/sad.gif)
GregAmy |
Oct 23 2017, 10:40 AM
Advanced Member Group: Members Posts: 2,290 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
To clarify...if it was the hose that failed, why do you need a new sender? They're not integral, correct?
And just to check if the engine is basically OK, just re-install the stock oil pressure light switch (or get one from the local auto parts store) and run a temporary jumper wire to your existing sender's wire. Dash light goes out, you have at least ~7-8 psi. That'll help you sleep better while you get the permanent repair parts. |
Lo-Fi Version | Time is now: 10th May 2024 - 02:18 AM |
