Oil Pressure sender hose blew out, need help |
rgolia |
Oct 23 2017, 09:51 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
So last night the hose from the engine to the oil pressure sender blew out and sent oil everywhere. fortunately I was about 1 mile from home. Lot of oil everywhere, hopefully I did not fry the engine. of course to figure that out I need to get a new sender in place. I would like to have a sender that works the green idiot light and can also work a gauge and of course I would rather not have a hose after this incident. Any suggestions on the sender type and where to get it and what to expect when i try to restart the car...after adding oil of course! (IMG:style_emoticons/default/sad.gif)
VaccaRabite |
Oct 24 2017, 12:15 PM
En Garde! Group: Admin Posts: 13,442 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
About the dual senders.
I don't like them. They trip the oil Idiot light much earlier then the stock sender. Some people don't mind that, but on some engines you can get the oil light on at hot idle but the oil pressure is still within spec. Disconcerting. I ran my hose to a T fitting, and have the pressure sender on one side and the stock idiot light sender on the other. Zach |
Mark Henry |
Oct 24 2017, 02:56 PM
About the dual senders. I don't like them. They trip the oil Idiot light much earlier then the stock sender. Some people don't mind that, but on some engines you can get the oil light on at hot idle but the oil pressure is still within spec. Disconcerting. I ran my hose to a T fitting, and have the pressure sender on one side and the stock idiot light sender on the other. Zach (IMG:style_emoticons/default/agree.gif) nothing beats the factory oil light switch. To me if you're really worried about oil pressure a big red light hooked to the idiot light is you best bet. |
GregAmy |
Oct 24 2017, 02:59 PM
Advanced Member Group: Members Posts: 2,290 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
About the dual senders. I don't like them. They trip the oil Idiot light much earlier then the stock sender. Some people don't mind that, but on some engines you can get the oil light on at hot idle but the oil pressure is still within spec. Disconcerting. (IMG:style_emoticons/default/agree.gif) nothing beats the factory oil light switch. To me if you're really worried about oil pressure a big red light hooked to the idiot light is you best bet. Ditto. I ended up removing the center console with its voltmeter and oil temperature and pressure gauges (with VDO dual sender that always turned on the light at hot idle), going back to the simple stock GEN and oil pressure lights. Haven't had a worry about oil pressure since... (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 05:40 AM |
