Oil Pressure sender hose blew out, need help |
rgolia |
Oct 23 2017, 09:51 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
So last night the hose from the engine to the oil pressure sender blew out and sent oil everywhere. fortunately I was about 1 mile from home. Lot of oil everywhere, hopefully I did not fry the engine. of course to figure that out I need to get a new sender in place. I would like to have a sender that works the green idiot light and can also work a gauge and of course I would rather not have a hose after this incident. Any suggestions on the sender type and where to get it and what to expect when i try to restart the car...after adding oil of course! (IMG:style_emoticons/default/sad.gif)
'73-914kid |
Oct 26 2017, 11:32 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
I would cut open your oil filter that was on the car. That's usually a consistent indicator of whether or not it smeared the bearings.
Fill it back up, drive it, and see if your oil pressure is good. If you damaged the bearings, you will likely see diminished oil pressure when the engine is hot as the journal-to-bearing clearance would have increased. It might be worth it to cut open the new filter you reinstall after a hundred miles or so of driving if all else seems well. |
Lo-Fi Version | Time is now: 10th May 2024 - 07:50 AM |
