Oil Pressure sender hose blew out, need help |
rgolia |
Oct 23 2017, 09:51 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
So last night the hose from the engine to the oil pressure sender blew out and sent oil everywhere. fortunately I was about 1 mile from home. Lot of oil everywhere, hopefully I did not fry the engine. of course to figure that out I need to get a new sender in place. I would like to have a sender that works the green idiot light and can also work a gauge and of course I would rather not have a hose after this incident. Any suggestions on the sender type and where to get it and what to expect when i try to restart the car...after adding oil of course! (IMG:style_emoticons/default/sad.gif)
rgolia |
Oct 31 2017, 09:46 AM
Got oil back in it and fired it up. After a short but painful squeal it fired up and ran. I let it idle for about 5 mins. Didn't sound bad, but there was what sounded like valve clatter on a beetle, although less noisy than a beetle. Will do a real road test run after I change the oil again this weekend. I am not confident that it will pass the test. I afraid that I am gonna need to start listing engine rebuild options. Parameters for the rebuild:
- It is a numbers matching car so keeping the case is a plus - I currently have Weber 44s - I would like more power but want to have heat exchangers - I do not want the car to be loud, I want to keep my exhaust as is (I have a borla unit) - I do not want to spend more on the engine than the car is worth (thats the wife talking) |
DM_2000 |
Oct 31 2017, 05:00 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
Got oil back in it and fired it up. After a short but painful squeal it fired up and ran. That's usually a very bad sign, at most an engine with wear will rattle until oil pressure is built up. Did the noise occur during cranking or immediately after the engine fired? Are you sure the alternator belt is tight? A lose belt will sequel then suddenly get quiet as the battery recharges. I let it idle for about 5 mins. Didn't sound bad, but there was what sounded like valve clatter on a beetle, although less noisy than a beetle. If the engine is louder than before, there are worn parts. I realize that is is possible to be more critical assessing noises after a problem occurs so that than into account. On most any engine, connecting rod bearings are the first to fail. A check for this is to warm up the engine then from idle, quickly snap the throttle to 50% and release, you might see 2500 - 3000 RPM in this test. If there is a sharp increase in noise, there is a loose connecting rod bearing. High revs / 100% throttle isn't needed. Will do a real road test run after I change the oil again this weekend. I am not confident that it will pass the test. I afraid that I am gonna need to start listing engine rebuild options. Parameters for the rebuild: - It is a numbers matching car so keeping the case is a plus - I currently have Weber 44s - I would like more power but want to have heat exchangers - I do not want the car to be loud, I want to keep my exhaust as is (I have a borla unit) - I do not want to spend more on the engine than the car is worth (thats the wife talking) Sounds like a stockish rebuild would fit your parameters. |
Lo-Fi Version | Time is now: 10th May 2024 - 05:13 AM |
