| rgolia |
Oct 23 2017, 09:51 AM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 720 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
So last night the hose from the engine to the oil pressure sender blew out and sent oil everywhere. fortunately I was about 1 mile from home. Lot of oil everywhere, hopefully I did not fry the engine. of course to figure that out I need to get a new sender in place. I would like to have a sender that works the green idiot light and can also work a gauge and of course I would rather not have a hose after this incident. Any suggestions on the sender type and where to get it and what to expect when i try to restart the car...after adding oil of course! (IMG:style_emoticons/default/sad.gif)
rgolia Oil Pressure sender hose blew out Oct 23 2017, 09:51 AM
Keith914 Buy a 928 SS braided brake line (Bruce Stone's... Oct 23 2017, 10:06 AM
bdstone914
Buy a 928 SS braided brake line (Bruce Stone... Oct 24 2017, 08:20 AM
GregAmy To clarify...if it was the hose that failed, why d... Oct 23 2017, 10:40 AM
cuddyk Check this out. Great kit.
http://www.42draftdes... Oct 23 2017, 10:41 AM
NeunEinVier
http://www.42draftde... Oct 31 2017, 11:04 AM
era vulgaris
So last night the hose from the engine to the oil... Oct 24 2017, 08:14 AM
Vacca Rabite About the dual senders.
I don't like them. Th... Oct 24 2017, 12:15 PM
Mark Henry
I don't like them. T... Oct 24 2017, 02:56 PM
GregAmy
I don't like them. ... Oct 24 2017, 02:59 PM
malcolm2
I don't like them. T... Nov 13 2017, 01:14 PM
rgolia Thanks all. I spoke with Chris at Tangerine and h... Oct 24 2017, 02:33 PM
DM_2000
Thanks all. I spoke with Chris at Tangerine and ... Oct 24 2017, 04:43 PM
cuddyk The kit I linked above has 3 available ports so yo... Oct 24 2017, 04:15 PM
rgolia Took the strainer out....no metal frags to speak o... Oct 26 2017, 10:03 AM
'73-914kid I would cut open your oil filter that was on the c... Oct 26 2017, 11:32 AM
DM_2000 Motor is probably OK unless it was in poor shape p... Oct 26 2017, 05:22 PM
Porschef Ralph, hope all is ok, were you using a grease gun... Oct 26 2017, 06:45 PM
rgolia Not sure of the origin of the hose, most likely ca... Oct 27 2017, 09:57 AM
rgolia Got oil back in it and fired it up. After a short... Oct 31 2017, 09:46 AM
DM_2000
Got oil back in it and fired it up. After a shor... Oct 31 2017, 05:00 PM
GregAmy - Put suspect numbers-matching engine in the basem... Oct 31 2017, 10:16 AM
McMark
- Put suspect numbers-matching engine in the base... Oct 31 2017, 10:23 AM
Dave_Darling Adjust the valves before you do your road test. I... Oct 31 2017, 11:03 AM
rgolia Fired it up this weekend and let it run for 15-20 ... Nov 6 2017, 03:03 PM
rgolia Well gave it a good warm up and then hit the road.... Nov 13 2017, 10:59 AM
McMark A quick refresh isn't outside your skill set. ... Nov 13 2017, 12:53 PM
pete000 Here is the kit I got from a Miata MX5 performance... Nov 13 2017, 01:05 PM
Dave_Darling
Here is the kit I got from a Miata MX5 performanc... Nov 13 2017, 02:45 PM
pete000
Here is the kit I got from a Miata MX5 performan... Nov 13 2017, 04:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:11 PM |
