Got home in 2nd gear....In need of some advice, clutch issue - cable? |
potomacmidget |
Oct 23 2017, 07:06 PM
I gotta have more cowbell.... Group: Members Posts: 161 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States |
Hi All,
Took my 1971 914 out to the pumpkin patch with the family yesterday and barely got home (in 2nd gear). Car was making squealing sounds when idling, stopped and in neutral, could only get it into 2nd gear. Managed to get home and got it in the garage, have not yet put it up on jack stands. Car was purchased about 4 years ago from a fellow member and is very well sorted by prior owner - all original. Figured I would ask for advice before I started poking around. I am pretty competent working on the car but have never adjusted the clutch - have had no issues with the transaxle. Any advice appreciated. Thanks in advance. Best, Reg |
GregAmy |
Oct 23 2017, 07:09 PM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Could you describe the sound and location of the squealing? And what did the clutch and shifter feel like as you tried to select gears, both stopped and moving? Could you select all the gears with the car stopped and the engine not running?
I'm wondering if you fragged a throwout bearing... |
potomacmidget |
Oct 23 2017, 08:05 PM
Could you describe the sound and location of the squealing? And what did the clutch and shifter feel like as you tried to select gears, both stopped and moving? Could you select all the gears with the car stopped and the engine not running? I'm wondering if you fragged a throwout bearing... HI - thanks for the reply. If I remember correctly there was a squealing sound as I pushed the clutch pedal in and out, guessing tranny issue, a bit of a howl sound too. perhaps I was not really disengaging the clutch. Plus I could only get it into 2nd gear when the car was running. Have not messed with it yet in the garage...thanks. |
Rand |
Oct 23 2017, 08:07 PM
QUOTE there was a squealing sound as I pushed the clutch pedal in and out A critical point of troubleshooting is exactly when it squealed... While the pedal was in OR out? A squeal does make me think throwout bearing as mentioned, but that would only apply if the bearing was spinning (clutch pedal in, clutch disengaged). |
GregAmy |
Oct 23 2017, 08:47 PM
^^^What he said. If the squealing was only with the clutch pedal in, I'm thinking throwout bearing, maybe clutch. And if you can easily select all gears with the engine off and the clutch pedal in or out, that reinforces it.
Try gear selections with the engine off, try diagnosing the noise during clutch pedal engagement, engine off and on, and let us know. |
potomacmidget |
Oct 24 2017, 05:23 PM
^^^What he said. If the squealing was only with the clutch pedal in, I'm thinking throwout bearing, maybe clutch. And if you can easily select all gears with the engine off and the clutch pedal in or out, that reinforces it. Try gear selections with the engine off, try diagnosing the noise during clutch pedal engagement, engine off and on, and let us know. Thanks Guys - appreciate the help - hope to check it out today or tomorrow....will follow up with my findings. |
wndsrfr |
Oct 24 2017, 06:29 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Hey Reg,
Sorry to hear that the 45 year old clutch assembly is giving up some of its reliability. Give me a call & maybe I can help look at it.... Regards, John |
crash914 |
Oct 24 2017, 06:41 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
If needed, I have a lift and spare transmission. I might also have a clutch cable and T/O bearing. In marriottsville.
Dr Evil |
Oct 25 2017, 08:10 AM
I bet its clutch as well. If you could get reverse, then you have internals of the box functioning (until they are ruined by clutch not letting go). Cant get 1 or 2 easily due to clutch drag. Upper gears will be less of a problem as you approach 1:1 ratios.
potomacmidget |
Oct 25 2017, 05:33 PM
I bet its clutch as well. If you could get reverse, then you have internals of the box functioning (until they are ruined by clutch not letting go). Cant get 1 or 2 easily due to clutch drag. Upper gears will be less of a problem as you approach 1:1 ratios. Dear All - thanks for the help - will go out and see if I can get it into reverse and any other gears and report back. Thanks again, Reg |
potomacmidget |
Oct 25 2017, 05:43 PM
I bet its clutch as well. If you could get reverse, then you have internals of the box functioning (until they are ruined by clutch not letting go). Cant get 1 or 2 easily due to clutch drag. Upper gears will be less of a problem as you approach 1:1 ratios. Dear All - thanks for the help - will go out and see if I can get it into reverse and any other gears and report back. Thanks again, Reg Ok - so I can get into all gears "except" reverse - and apparently that is not good per Dr. Evil; and the clutch is super spongy, I don't have any resistance until the pedal travel is like half way, and unfortunately I need to move a bunch of junk to get the car up on jackstands so that is the next step. Thanks again in advance for weighing in on this..Best,Reg |
flyer86d |
Oct 25 2017, 05:54 PM
Member Group: Members Posts: 425 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
I’ll bet the throw out bearing failed. I had that happen on my 83 SC Targa daily driver on the way to work one morning. I popped the motor and trans out and replaced the clutch while I was at it along with the chain tensioner upgrade. All was good after.
Charlie |
Dr Evil |
Oct 26 2017, 02:08 PM
I bet its clutch as well. If you could get reverse, then you have internals of the box functioning (until they are ruined by clutch not letting go). Cant get 1 or 2 easily due to clutch drag. Upper gears will be less of a problem as you approach 1:1 ratios. Dear All - thanks for the help - will go out and see if I can get it into reverse and any other gears and report back. Thanks again, Reg Ok - so I can get into all gears "except" reverse - and apparently that is not good per Dr. Evil; and the clutch is super spongy, I don't have any resistance until the pedal travel is like half way, and unfortunately I need to move a bunch of junk to get the car up on jackstands so that is the next step. Thanks again in advance for weighing in on this..Best,Reg Clutch is not releasing. Drop the trans and take a gander. |
potomacmidget |
Nov 5 2017, 04:47 PM
Dear All,
Thanks for all the assistance, and wanted to provide a follow up. Wndsrfr (prior owner) bailed me out - over the last 2 weekends in two trips with little assistance from me he pulled the transmission and turned out the throwout bearing was seized, as of today new clutch kit installed and all is good. Thanks again John! I definitely owe you! Best, Reg |
GregAmy |
Nov 5 2017, 08:11 PM
Nailed it, post #2. Glad you got it fixed!
crash914 |
Nov 6 2017, 04:54 AM
Dr Evil |
Nov 6 2017, 08:24 AM
wndsrfr |
Nov 6 2017, 09:04 AM
crash914 |
Nov 6 2017, 10:17 AM
Yummy, all the balls look missing?
potomacmidget |
Nov 7 2017, 07:56 PM
Lo-Fi Version | Time is now: 15th May 2024 - 11:08 AM |
